No power to window motor
Old 07-13-2014, 08:51 PM
Kagnus
Kagnus's Avatar
Default No power to window motor
My driver side window motor is working(i have tested it) but not receiving any power. Passenger side operates properly. I checked fuse #44 and it is intact. Pulling it cuts power to at least the passenger side. I assume that the windows are on the same relay. Any help is appreciated.
Kagnus is offline
Old 07-14-2014, 07:27 PM
Nuke
Nuke's Avatar
Dig into the wiring diagrams here: http://iihs.net/fsm/?dir=40
Keep us posted.
Nuke is offline
Old 08-07-2014, 06:12 PM
Kagnus
Kagnus's Avatar
So I could not find a problem with any fuses and bought a new/used switch. It worked when I initially plugged it in and left to complete everything another day. Went back and turned the accessories on and the switch suddenly doesn't work. Again. I've run out of ideas.
Kagnus is offline
Old 08-08-2014, 02:29 PM
Nuke
Nuke's Avatar
If you're saying you put a new switch in and it worked but later didn't, then I'd double check the switch functionality and then look for intermittent wiring. The fact that it momentarily worked should tell you that the motor is good and you have power (or HAD power).
Nuke is offline
Old 08-10-2014, 05:32 PM
Kagnus
Kagnus's Avatar
Figured out it wasn't the switch. Once I figured out which prongs went where the switch tested good. Loss of power is only on RF window wires. So Y, VT-LG, and WH-BL wires do not show continuity when tested with R-LB power wire. The power loss must be at the smart junction box.... right? I'm not sure where to start on that one. Suggestions welcome. I'm going to get down there and do a visual check.
I had the water-coming-in-through-the-dash problem with leaves that had clogged the drainage under the cowl so that may be related but I took care of that problem a couple of years ago.
Kagnus is offline
Granatelli Sales
01-20-2020 12:34 AM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Luke9222
10-22-2015 11:55 PM
Pyrate Dave
09-10-2015 07:30 PM
tmdm
09-04-2015 06:45 PM
Quick Reply: No power to window motor
