My Mustang keeps stopping
Old 05-19-2014, 02:17 PM
Aussie24
Aussie24's Avatar
Default My Mustang keeps stopping
MY 95 GT starts runs for 30 second or sometimes 2 minutes then it stops like it has run out of gas. It will start back up again but same thing
I changed the fuel filter which a lot of brown gas came out of the engine side of filter ran gas out to check it and was ok ,checked that the pump was working , New plugs and O2 senor.
There is a couple of galons of gas in the tank but the gauge is all over the place says 1/2 full then turn the key and it goes down to 1/4 tank.
Would love some advice
Aussie24 is offline
Old 05-20-2014, 10:01 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I would start by putting more gas in it, then verify you have fuel pressure around 35-40 lbs. How did you verify that your fuel pump was good?
Old 05-20-2014, 11:01 AM
Aussie24
Aussie24's Avatar
I took the tank side of the fuel filter off and put it in a bucket and turned the key on and it came out and stopped when I cut the power.
Aussie24 is offline
Old 05-20-2014, 02:20 PM
Aussie24
Aussie24's Avatar
Today it started right up, Then it revered it self the went normal the went a bit more and stalled but then the radiator fan came on and I heard a clicking coming from where the relay for fuel and fan is. Could it just be the relay?
Aussie24 is offline
Old 05-21-2014, 07:25 AM
88 orangepeel notch
Could be the relay, but sounds like a bad ignition switch, or even a bad ECM (computer) My foxbody did this when I first bought it, traced the problem to the computer and that fixed it, but it is rare that they go out. Try wiggling the key when the problems occur. And I have no idea why your fan kicked on unless the motor was that hot.
Old 06-02-2014, 09:49 PM
aode08
aode08's Avatar
http://www.autozone.com/autozone/par...7020_880641_0_
The above part is overheating.
Usually the result of a bad fuel pump and fuel filter.
Parts needed at this point in year
All 5 parts.fuel pump, fuel pump filter, ccrm module,coil pack,and igntion control module/tfi module, needs replaced. Use a stock fuel pump, high drian units will fry the module again.
This is a very common issue with your year car.
aode08 is offline
Old 07-09-2014, 06:54 PM
Aussie24
Aussie24's Avatar
I did a pressure test on the fuel pump it read 40psi with the key on and car was cold but then the radiator fan kicked on, Why I don't know but the psi went down to 30. I started the car and the psi was just over 40.Not sure if the fan came on and car stopped or not.
What could this be
Aussie24 is offline
Old 07-10-2014, 07:34 AM
88 orangepeel notch
I'm not familiar with the SNs, but I'd pull codes now to see what's up. Something is amiss in Mustang Land.
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
importsmasher
10-09-2015 04:42 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: My Mustang keeps stopping
