will it work???
will it work???
I have a 95 gt with an automatic and I have a chance to pick up a running 302 and good transmission out of a 1992 crown vic for a good price. will the transmission interchange?
I believe the crown vic used a 4R70w trans. It will work in your car as its been done before , I even think the 95 pcm will communicate with the trans, but the plug is different and youll need to find a pin out digram of each trans to make it work.
Got this info from Wikipedia. (So take it with a grain of salt). According to them the 92 crown Vic had an AOD transmission. 94-95 mustangs used the AODE. They also state that the AOD uses a shift linkage where the AODE uses electric solenoid a to shift the transmission and are not interchangeable. They say you can use the stronger gear sets from a 4R70w in an AOD.
Blue, this is what I have heard since I was on here to update. I am planning on going ahead and picking up the motor and trans any way just to start building the 5.0 for my ranger.... Thanks for the info guys
