Authenticating
Authenticating
How can I confirm a late 80's car was an original GT car? Want to make sure they didn't slap on the GT package.
Did Ford stamp the engine block with the VIN? If they did, where can I find this to make sure it is the original block?
Did the GTs come with a sun roof stock? I will pass on the car if a hole has been chopped in the roof.
Lastly, how can I confirm the trans is original (T5)?
Tried to buy one of these years ago, but couldn't afford it. Now is different! I think I may have found my GT!!
Appreciate any help/advice.
Thanks.
Thanks.
Silly question but late 80s GTs are never gonna be a collector car so why the concern with it being an original GT? I'd be more concerned with it just being a solid, working car! Here's a link to the Mustang GT registry. This should help with Vin. and door tag information. This should provide you with some info but as far as the sunroof I don't think there is any way of knowing it's original without a build sheet. Ford did offer factory stock sunroofs in foxbodies. I'm sure a quick google image search should have pictures of the factory sunroof. The T5 transmission will have a generic part number on it but I don't think it'll have a specific number to a certain car it was originally installed in. The door tag should have a number 2 on it for a stick shift car.
http://www.mustanggt.org/vin.htm
Thanks for the reply and the info!
I am a stickler about original and know very little about the Mustangs and just want to make sure of what I am getting. If it is molested I do not want the car, of course. Seller could almost tell me anything and I wouldn't know any better. The GT sticks are getting hard to find it seems. I nearly bought a black car like this in my late teens, but just couldn't afford it at the time. This car would be great if it is what I am hoping.
Waiting on the VIN now to see what that reveals.
Hello, love me some 4 eyed mustang. I owned a 85 coupe for a bit. The block is stamped and the number can typically be found under the starter. You are probably going to have to remove the starter, I know I did on mine.
The build sheet of the car should be under the carpet, typically they are under the drivers seat or in the hatch area under the carpet as well. If this is a vehicle you are looking at buying you might have to talk the owner into letting you pull the seat to remove the carpet. Even then there is still no gurentee it will be there.
Another thing for you to do is pull the bucktag. It typically will be behind the driver headlamp and IIRC will be screwed in. The information should be stamped on that tag with options the car came with.
Here's a pic for refrence on the buck tag:
Good luck and let us know what you find out!
Hope that helps.
Hope that helps.
I see the gauge cluster has been removed for aftermarket gauges. Wondering if the dash was cut out to make room for the gauges...? I know the guy will say no if I ask this.
VIN does show the E motor and GT. It looks to be in decent condition. Outside it has a broken tail light lens, poor paint and without any major damage to the body panels. Original wheels. Trans. is popping out of second, but runs great otherwise. Cannnot comment on interior or engine bay.
Thanks again guys I do appreciate the feedback.
Hope that helps.
Hope that helps.
Thanks for info!
Waiting for more pics of interior and engine bay now.
