Help with Bucking at low RPM's in all gears when not under load
Old 03-30-2008, 09:55 AM
brywatz
brywatz's Avatar
Default Help with Bucking at low RPM's in all gears when not under load
My stang runs great except when I'm tryint to drive slow through a parking lot, or if the RPM's get too low in any gear, then it starts to buck bad. I have to push in the clutch or give it gas to make it stop. Why is this, I know its a pretty common problem. I know I have excessive play in my rear of U-joints that makes it feel even worse.
brywatz is offline
Old 03-30-2008, 01:35 PM
1985stang
1985stang's Avatar
Default RE: Help with Bucking at low RPM's in all gears when not under load
How low are the rpms we're talking about here?
1985stang is offline
Old 03-30-2008, 02:06 PM
brywatz
brywatz's Avatar
1500 or so
brywatz is offline
Old 03-30-2008, 03:14 PM
1985stang
1985stang's Avatar
hm, that's not as low as i thought you were gonna say. idk what the problem is, but you are definately gonna want to fix your u-joints before your driveshaft falls off.
Omgitsa88Stang
10-05-2015 07:33 AM
musnicki
09-23-2015 07:11 AM
SteelerNation82
09-16-2015 07:11 AM
dalefrancis88
09-11-2015 07:15 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Help with Bucking at low RPM's in all gears when not under load
