Tech articles and how to's (Updated Often)
Old 10-26-2006, 02:32 PM
HRnB
Administrator
HRnB's Avatar
Default Tech articles and how to's (Updated Often)
Hey guys!
Planning on installing that new t/b plenum this weekend? Or how about a catback or X-pipe? Underdrive pulleys? Anything? Chin Spoiler?
Make sure you take picutres of the installation process and do a technical, thorough writeup and submit to me via PM ANY Site Moderator and if it makes muster, the Admins might be so kind as to bless you with a contributor tag!
It's not that hard to do and we're trying to expand our tech "How To's" and who better than the members to do them!
Thanks all!
Acer & Staff
This arrangement of tech articles was provided by Acer2428 & Edited by Site Moderators.
Thanks Everyone. [sm=smiley20.gif]
How to: Tint your head lights and tail lights
How to: Install HIDs
Bad Boys of the 4.6 Section
Rides of the 4.6 Section
Texas Hot Rods 2v In the 12's On a Budget, With Videos
Watch Before Posting
Brake configurations with Bullit Wheels
Moving Rear Spoiler Back on 99-00 Mustang
5 Components To a 12 sec N/A 99-04 GT
Basic Info/ FAQ
Bolt On dyno testing
Mustang Suspension Information
N/A Cobra vs. GT Differences?
Mach 1 Grill Delete Part #
Methanol Injection Facts
Gas Mileage
Does Your 4.6 stall/die at idle or cruising speed?
Spark Plug Info
Modular Motors and Lifters: No
97 Cobra Engine Rebuild
Camshafts?
4V Head Info
T-45, 3650: Manual Transmissions
( See also T-45 to T-3650 Swap How To!)
TKO 500/600/T56 Swap Information
THE Gear Thread
Basic Bolt-Ons
Tuner Info
Dyno Expectations and Advice
What Octane do I need?
The Ins-n-Outs Of Lowering Your Stang
( See also Basic Suspension Install How To)
Throttle Body and Plenum Comparisons
96-98 PI Headswap Info
4.6 Exhaust Sound Clips
Gear Calculator
Plastic Intake Lawsuit Info
Tire and Wheel Size Calculator
Mustang Trouble Codes
Interesting facts about injectors, by 01Steed
03-04 Cobra bumper swapFAQs
How To: Air Silencer Removal
How To: Changing Your Spark Plugs
How To: Gas Pedal Mod
How To: JLT Cold Air Installation
How To: Throttle Body and Plenum Install
How To: Aftermarket Shifter Install
How To: T-45 to T-3650 Swap
How To: Cobra Brake Swap
How To: Speed Cal Install
How To: Electronic Gauge Install (99-04)
How To: SLP LineLock Install
How To: Basic Suspension Install
How To: Underdrive Pulley Install
How To: IAC Rev Mod (Fixing hanging RPMS)
How To: Make Mach/Bullitt guages work in a GT
How To: Make your own MIL's
How To: Window Repair
How To: Paint Interior Trim
How To: Wash your engine bay
HowTo: Installing a Raptor Shift Light
How to: Program a PATS key
COP info
How To: Degree modular cams
RETURN STYLE FUEL SYSTEMS EXPLAINED
OFFICIAL SUSPENSION GUIDE
T-3650 ~ T-56 swap with complete instructions
How to save your Bullitt wheels from the scrap pile
Turbos: Myth's Uncovered
BUILD YOUR COBRA BRAKE KIT
How To: UPR Coil Over Install WITH PICS
HOW-TO: ProCharger P-1SC Rebuild
HOW-TO: Shut Off Seat Belt Warning
HOW TO: BUILD YOUR OWN ENGINE 56K beware
HOW TO: Upgrade brakes
How To: Re-Build Vortech Supercharger
How To: Slow Down Sequential Tail Light Rate
"calibrated" MAFs...
HRnB is offline
Old 03-03-2009, 11:23 AM
lizzyfan
Underboss
lizzyfan's Avatar
Courtesy of BlackMage
Mustang Replacement Floor Carpet (94-04)
http://www.americanmuscle.com/replac...4-install.html
lizzyfan is offline
Old 05-24-2009, 07:07 AM
lizzyfan
Underboss
lizzyfan's Avatar
Traction control disable
https://mustangforums.com/forum/6089074-post1.html
lizzyfan is offline
Old 12-18-2010, 11:06 PM
everett
everett's Avatar
Great write ups.... Thanks to the posters who took the time to write them up
everett is offline
Old 08-16-2011, 08:36 AM
rollintechno
rollintechno's Avatar
Is there an article/how-to on replacing the intake manifold on an '01 GT 4.6L SOHC?
rollintechno is offline
Old 09-06-2011, 05:21 PM
keysflier
keysflier's Avatar
Default Another "How-To" - fog light rewiring
If anyone is interested, I figured out how to rewire the fog lights on my 97 GT so they work through the regular switch and relay independent of the headlights. I'll walk you through how I did it if you want to know.
keysflier is offline
Old 01-08-2012, 01:41 AM
RhymeTyme
RhymeTyme's Avatar
Default 98 4.6 litre swap over to 2001 4.6 litre PI
What componets have to be changed over if any so a 2001 4.6 litre PI can be installed in place of a 98 4.6 litre in a 98 GT Mustang? The PI came out of 2001 GT convertible with automatic transmission. The 98 is a 5 speed. Is anything custom or special in order to do the engine swap?
RhymeTyme is offline
Old 05-20-2012, 07:13 AM
ESABATM
ESABATM's Avatar
no except maybe the auto trans flex plate, if the attach holes on the end of the crank number six you're fine. If they are eight you need a flex plate off a 99-00 year car with an automatic.
ESABATM is offline
Old 05-24-2012, 09:11 PM
Syracuse315
Syracuse315's Avatar
How To: Replace Front Wheel Bearing Hub Assembly
Syracuse315 is offline
Old 03-26-2014, 12:13 AM
Tkdetrick
Tkdetrick's Avatar
I have a 2000 GT with the Windsor block, will Romeo heads bolt on without issue excluding valve covers? And any other differences that could cause issues during engjne build?
Tkdetrick is offline
Quick Reply: Tech articles and how to's (Updated Often)
