O/R X Pipe Install
Old 07-29-2014, 12:39 PM
performanceredgt
performanceredgt's Avatar
Default O/R X Pipe Install
I've seen this asked a couple times but I saw variation in the answers, but can someone with moderate handy man skills and all the right tools install an O/R X Pipe themselves?
performanceredgt is offline
Old 07-30-2014, 10:44 AM
Yes it can be done relatively quick also , that is if the old pipe isn't to far rusted to take off easily, and both pipes have the same fitment. Make sure you saturate all the bolts and nuts with some kind of penetrating over night. The hard ones to get off will be the header or manifold nuts off of the studs. If these are rusted to bad they can be a pita.
If I had to change mine out right now and had another pipe for it, I could go out and swap it in about 1/2 hr. Of course I already know what tools I would need to take under there with me, so I wouldn't have to climb in and out to find the right sized socket. If you have never changed a mid pipe out it will take you a little while but not to long.
Old 07-30-2014, 06:54 PM
art02gt
art02gt's Avatar
The hardest part is the passenger side manifold bolts since the cats are in the way, but it's manageable. you might need a swivel and maybe some extensions. you won't believe how easy the install goes without the cats in the way.
art02gt is offline
2007CalSpec
12-13-2020 11:42 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Webster454
09-07-2015 04:59 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: O/R X Pipe Install
