Knock in front suspension
Old 07-22-2014, 11:45 AM
vincep99
vincep99's Avatar
Default Knock in front suspension
My 2007 GT has ~ 50K miles and this spring it developed a knock in the right front side when I go over a bump. I checked the tie-rods, sway bar, and ball joints, everything seemed OK. I changed the struts (I figured it was time, esp since I live on a rough road), knock still there.
I did search elsewhere on this forum, saw nothing I have not tried.
Any ideas?
Also, I know there is a right way and a wrong way to check the ball joints (loaded vs unloaded), can someone confirm the right procedure?
vincep99 is offline
Old 07-22-2014, 12:01 PM
Phil1098
Phil1098's Avatar
I see where you replaced the struts, did that include the upper strut mounts? That is a known issue and most people replace them with the FRPP units.
Phil1098 is offline
Old 07-22-2014, 05:24 PM
illini4
illini4's Avatar
Make sure your sway bar end links are good. One of mine had a torn boot, and was loose and making a knocking nose on rough pavement.
illini4 is offline
Old 07-22-2014, 07:37 PM
JTS64
JTS64's Avatar
Check the front brake caliper bolts. I had a knocking noise when going over bumps and rough roads in the right front. I found that when I had my calipers painted the shop did not tighten the bolts to spec and they started backing out after a couple of months.
JTS64 is offline
Old 07-23-2014, 11:38 AM
vincep99
vincep99's Avatar
Thanks for the responses!
I did replace the upper strut mounts. My old ones looked iffy so I went ahead and bought the entire assembly (quick struts), which also saved me a bunch of time.
I checked the sway bar end links but I will check them again.
I will check the front brake caliper bolts as well. I just installed them a couple of months ago; I torqued them to spec and also used 242 Loctite, but it is worth it to check them again.
vincep99 is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: Knock in front suspension
