hot starting problim
Old 12-15-2007, 09:20 PM
txstroker
txstroker's Avatar
Default hot starting problim
Got a 95 mustang that does not like to start after ithas heated up any advice.
txstroker is offline
Old 12-15-2007, 10:06 PM
Dave5point0
Dave5point0's Avatar
Default RE: hot starting problim
Your starter is heat soaked, just like mine. Buy a new one!!! You have aftermarket headers?
Dave5point0 is offline
Old 12-15-2007, 11:11 PM
92cobra
92cobra's Avatar
could also be a tfi module issue if the 95s have them, not sure if they do or not.
92cobra is offline
Old 12-15-2007, 11:21 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: Dave5point0
the key word used was "does not like to start after warmed up".....not cranks slow......if you have a hot soak extended crank before fires up.....then checking fuel pressure may be a good idea to see if you have an leak down in the fuel system occuring....if that is what you are refering too...also if it cranks but won't start check ignition and see if it's got spark when prob occurs
mjr46 is offline
Old 12-15-2007, 11:28 PM
Dave5point0
well mine is DEFINITLY the starter. It starts GREAT cold, then i drive around and it runs fine. Then i stop, and the starter doesn't made a damm noise, then after a few minutes it cranks SUPER slow, then after a few more minutes it cranks a little faster and may or may not work, but after a half hour the starter spins fast enough to get the motor cranked for sure. I just gave out the best advise with the very little info given
Old 12-15-2007, 11:31 PM
mjr46
mjr46's Avatar
understandable..mine used to do that but my issue was a result of a weak battery...optima and a 100 amp singlw wire powermaster alt soved all my issues ftw!!!!
mjr46 is offline
Old 12-15-2007, 11:44 PM
92cobra
92cobra's Avatar
do you have underdrive pullies mjr46? If so, how did that alt work out for you. I discharge at idle when i have my accessories on like heat on full, rear defrost, radio, electric fan, and i need a bigger alt. What do you recommend?
92cobra is offline
Dave5point0
Yea, i hoped it was the battery when i bought the car, i replaced the battery and alt the day after i bought it, didn't do a damm thing, $ wasted .
Old 12-16-2007, 07:20 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: mjr46
Yeah, more info is needed from the OP I like how ppl always jump in w/o knowing all the facts.
PRO50SC is offline
Old 12-16-2007, 07:57 AM
z24stang
z24stang's Avatar
I am curious as what the problem could be also.My car does the same thing,starts well cold but if its hot(after half hour or moreof driving)and turn it off,Ihave to wait a half hour or she wont start.
z24stang is offline
Quick Reply: hot starting problim
