Hot engine
Old 03-26-2013, 06:40 PM
1990gtf
1990gtf's Avatar
Default Hot engine
I recently rebuilt and installed my 302 on my 1990 GT. Heres a list of some of the new parts I used
Underdrive pullies
70mm egr and TB
explorer upper and lower intake
e303
1.6 pedestal RR
cold air intake
ford racing wires
msd cap and rotor
oe copper plugs
problem/s I'm having now are it starts fine (little rough idle) but after running about 3-4 minutes the engine gets too hot to touch all over. Temp gauge says its fine Coolant is flowing but everything just seems wayyy too hot. Any ideas?
Another thing is codes. I get 22,23,85 I've searched what all these mean but tons of different answers on how to go about them.
Any help on any of this is greatly appreciated.
1990gtf is offline
Old 03-26-2013, 09:47 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check and make sure the vaccum line going to the egr valve is not applying vaccum to the egr valve holding it open, if it is, sounds like the evr vaccum selonoid is bad. This would explain the excessive heat as the egr is dumping hot exhaust gases into the intake, also would explain rough idle.
mjr46 is offline
Old 03-27-2013, 04:43 AM
1990gtf
1990gtf's Avatar
That's odd. The egr valve had a vacuum cap on it from when I got it so I just left it and didn't hook one up on the rebuild.I'll run a vacuum line to the egr after I get home from work and see what happens. I thought coolant flow was my problem at first but its not. It's weird after like four minutes any part of the engine gets so hot you'll get burned from touching it.
1990gtf is offline
Old 03-27-2013, 05:21 AM
sounds like you have an air pocket some where in the coolant system . Do you have a mechanical temp gauge or are you going by the stock dash cluster gauge?
3-4 min seems awfully soon for the engine to get that hot though. Mine doesn't even open the thermostat for about 10 min. Check your timing , to much advance will cause the engine to get hot fast, as will a blown head gasket.
Old 03-27-2013, 11:46 AM
mjr46
mjr46's Avatar
if egr vac line is capped off, vac holding it open is not the prob, remove egr valve and check pintle and see if it is partially held open from carbon build up, I had a 94 do this a few months back, After about 2-3 min of run time the intake was as hot as a firecracker, 'bout burned the snot out of my hand when I discovered the issue.
mjr46 is offline
Old 06-02-2013, 10:13 PM
1990gtf
1990gtf's Avatar
Sorry to dig up an old post of mine but I'm still having a problem and might have found the issue but need some opinions. The engine doesn't start to get hot until 10-15 minutes of idling. I've replaced the radiator since I last posted on this. After looking online I went and turned the radiator fan when it was cold and it just kept spinning, same thing when its warmed up. I know it more than likely needs replaced but do you guys think this is the culprit of this problem?
1990gtf is offline
Old 06-03-2013, 06:40 AM
88 orangepeel notch
88 orangepeel notch's Avatar
The clutch on your fan is shot. Yes it won't pull the air thru to cool radiator. There should be some resistance when spinning by hand. Well do you mean on a cool motor you give the fan a spin an it keeps spinning by itself for a couple revolutions? It should stop spinning as soon as your hand leaves the blade.
Old 06-03-2013, 03:52 PM
1990gtf
1990gtf's Avatar
This thing makes like 7-8 maybe more revolutions when you spin it when its cold. I've been trying to figure this problem out for months and it looks like this is it. I've already started ordering parts for the 3g alt swap and electric fan swap.
1990gtf is offline
Old 06-03-2013, 04:24 PM
88 orangepeel notch
Yep, that fan was not working. Its nice when you finally find its something simple. Congrats on your research, and good luck on your mods.
Nick Oliver
10-17-2018 04:22 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Hot engine
