'88 5.0 rebuild and now doesn't run correctly
Old 05-30-2013, 10:12 PM
dgiblin21
dgiblin21's Avatar
Default '88 5.0 rebuild and now doesn't run correctly
So my cousin had some guy rebuild his '88 5.0L and now it running extremely rough backfires and cats are glowing red. Where should I start to diagnosis this problem?
dgiblin21 is offline
Old 05-30-2013, 10:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check the firing order
mjr46 is offline
Old 06-02-2013, 06:20 PM
dgiblin21
dgiblin21's Avatar
Firing order is correct timing is correct and cats were hollowed out as an attempt so check if they were clogged they no longer glow but car still runs like crap very rough and backfires thru intake
Old 06-02-2013, 08:21 PM
mjr46
mjr46's Avatar
what cam was used? roller cam?? flat tappet?? and what firing order are you using, details on the rebuild and parts used??
mjr46 is offline
Old 06-04-2013, 01:25 PM
dgiblin21
dgiblin21's Avatar
it's bored 10 over, flat racing pistons, rv cam, machined heads, polished crank, and spin balanced engine i'm trying to get more info from him but i'm living in another state at the moment and cant look at the car myself until july :/
Cannibal_carnies
03-02-2023 06:17 PM
YoungStangsMan
09-05-2015 07:01 PM
labudski
08-24-2015 07:23 AM
MXBT187
08-20-2015 02:36 AM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: '88 5.0 rebuild and now doesn't run correctly
