Signs of bad distributor?
Old 03-14-2006, 09:08 PM
philly3384
philly3384's Avatar
Default Signs of bad distributor?
When ur distributor is going bad what are the signs.
philly3384 is offline
Old 03-14-2006, 09:45 PM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: Signs of bad distributor?
No spark? Whats your problem. What makes you think its the ignition causing your problem.
ZachW04Stang is offline
Old 03-14-2006, 09:58 PM
philly3384
philly3384's Avatar
Car will run good for a little while then start to run like half of its power and the fuel pressure is fine.
Old 03-14-2006, 10:09 PM
Joel5.0
Joel5.0's Avatar
What symptoms?...missing cylinders?....no starts?...hard starts?...backfiring?....
Joel5.0 is offline
Old 03-14-2006, 10:48 PM
philly3384
philly3384's Avatar
The car will start fine and it doesnt backfire at all. It just runs for awhile and then starts to be very sluggish like i have no power.
Old 03-14-2006, 11:02 PM
ikeybmg
ikeybmg's Avatar
i started hearing a weird grinding type noise in my motor once, bout a week later, my distributer broke.
ikeybmg is offline
Old 03-14-2006, 11:13 PM
Joel5.0
Joel5.0's Avatar
Check the inside of the dizzy (as Ikeybmg suggests), a bad stator sensor/pickup coil or shaft bushing/bearing can also cause that problem....any funny indications on the tach (jumping needle, etc)?....what about the exhaust?...OEM, aftermarket, still have cat cons installed?
Joel5.0 is offline
Old 03-15-2006, 12:03 AM
philly3384
philly3384's Avatar
my idle usually never stay still like varies from 900 to 1100 and thats all the needle jumping that i know of. The exhaust is o/r h and flowmaster 40's. Is there any way to see if the bad stator sensor/pickup coil or shaft bushing/bearing are bad?
Old 03-15-2006, 07:43 PM
Joel5.0
Joel5.0's Avatar
Suggest you start by doing a DIY KOEO/KOER self-test first...if you don't have a miss, hard-start, no-start symptom, the problem might be elsewhere (TPS, MAF, ECT, ACT, wiring, O2's......). The codes scan will help in starting the process to id what might be causing it. Since you mentioned the idle problem also, check this DIY " 5 maintenance steps" to help in correcting it (includes the MAF cleaning procedure).
To check the dizzy for excessive shaft play, you would have to remove it....one sign of a possible problem with the bushing/bearing, is the presence of rust-like debris under the vanes rotor and the stator sensor.
Let us know if you run the codes tests, and which ones show up. GL
Joel5.0 is offline
Old 06-06-2013, 12:26 PM
Lee Kelsoe
Lee Kelsoe's Avatar
I know I'm resurrecting the dead here... but I have tried to find a definitive answer for this exact problem to no avail... what ended up being the problem philly?
I have thrown almost every part at this problem and can't figure it out...
Lee Kelsoe is offline
Quick Reply: Signs of bad distributor?
