Rear Tires on a Foxbody...how wide can i go?
Old 03-18-2006, 10:29 PM
scottistang
scottistang's Avatar
Default Rear Tires on a Foxbody...how wide can i go?
Looking at getting a new set of rear 17" Cobras for my mustang. Was curious as to how wide of a rear tire i can put on it if i go with the 10.5" rim. Ive heard of people running the 315's possibly but you have to remove the quad shocks. Any input would be great thanks guys
scottistang is offline
Old 03-18-2006, 10:31 PM
ikeybmg
ikeybmg's Avatar
Default RE: Rear Tires on a Foxbody...how wide can i go?
it would take some work to fit 315's. more than just the quadshocks. im not sure what the biggest would be but i know the 315's would require modification to the fenders.
ikeybmg is offline
Old 03-18-2006, 10:40 PM
grabbem88
grabbem88's Avatar
255's45/17's rub...the front too go with a 235/ 45/17
grabbem88 is offline
r.barn
r.barn's Avatar
from reading past posts in here
you can "easily" fit 275's when you remove the quad shocks.
anything past that and you will have to roll the wheel well lips
or custom rims or other mods.
a good wheel/tire shop should be able to take some measurements
and be able to talk with you.
fitting 315's under there is going to a pretty custom job.
Personally I'm hoping to get about 295's under there with
just a little bit of body work.
r.barn is offline
Old 03-18-2006, 10:42 PM
grabbem88
grabbem88's Avatar
not if the stang is lowered...mine rubbed....i'm sorry they were 275/40/17's
Old 03-18-2006, 10:45 PM
Steeda1716
Steeda1716's Avatar
i have 245/45/17 on all 4 of my 17inch cobras,The front rub only when you make a wide turn,If i had to do it over again i would go with 235's in front and 245's in back...
Steeda1716 is offline
Old 03-18-2006, 10:46 PM
infantrycav
infantrycav's Avatar
275's require you to remove the quad shocks? I anticipated rolling the fender but what does removing the quad shocks entail?
infantrycav is offline
Old 03-18-2006, 10:49 PM
ikeybmg
ikeybmg's Avatar
just gt an aftermarket set of adjustable lower comtrol arms. and then just ake them off. the ones that run sideways are the quads.
ikeybmg is offline
Old 03-18-2006, 10:54 PM
infantrycav
alright i understand now. the 275 bulge a little but they seal on a 9" rim though right? my buddies got 315bfg drag radials on his z-28, he's got 17x10." chrome cragars, they protrude from the wheelwell a bit but look bad-***. 315 will make for some spendy tire bills though.
Old 03-18-2006, 10:57 PM
ikeybmg
ikeybmg's Avatar
they will seal on a 9in wheel
ORIGINAL: infantrycav
ikeybmg is offline
Quick Reply: Rear Tires on a Foxbody...how wide can i go?
