adjusting bands on c4
Old 03-26-2006, 08:36 PM
65turbo289
65turbo289's Avatar
Default adjusting bands on c4
theres the lock nut on the left and i think on the right(*passenger) which one is low and which is interm. bands?
65turbo289 is offline
Old 03-27-2006, 12:04 AM
THUMPIN455
THUMPIN455's Avatar
Default RE: adjusting bands on c4
Intermediate band is the front one with adjusting nut on the drivers side.
Low reverse band is the rear most one with the adjusting nut on the passenger side.
For everyone else who might consider doing it also.
Adjustment procedure:
INTERMEDIATE BAND
1: remove and discard locknut and install a new one (more than just a good idea here folks)
2: torque adjusting screw to 10ftlbs. (thats the one inside the nut, not the nut itself)
3: Back off adjusting screw exactly
a. 1 1/2 turns on 1964 C4
b. 1 3/4 turns on 1965-1981 C4
c
4: Hold adjusting screw from turning and tighten locknut
LOW REVERSE BAND
1: loosen lock nut several turns
3: Back off adjusting screw 3 full turns
4: hold adjusting screw from turning and tighten lock nut
10 ftlbs isnt very much so you will need a very small ftlb torque wrench. If you can find one that has both inch lbs and ftlbs on it, that would be the one to use.
THUMPIN455 is offline
Old 03-27-2006, 04:42 PM
65turbo289
65turbo289's Avatar
PERFECT thanks!
Old 06-19-2019, 11:59 AM
James Morris
James Morris's Avatar
I assume this can be performed with trans in car. Nothing Im missing? Just crawl under....quick job.
James Morris is offline
shelbymustangdan
04-09-2018 10:36 PM
iateadonut
12-04-2014 12:53 PM
live2shred303
07-30-2012 02:56 PM
Shaunmac9128
02-21-2010 11:26 PM
FoxGT
04-14-2005 07:01 AM
Quick Reply: adjusting bands on c4
