87 gt 85 mph to 200 mph gauge calibration
Old 03-03-2004, 07:22 AM
pgreder
pgreder's Avatar
Default 87 gt 85 mph to 200 mph gauge calibration
I have a 200 mph face plate but my speedo is the old 85mph in an 87 gt. Does anyone know what to do to calibrate the 85mph speedo to read correctly on a 200mph face?
pgreder is offline
Old 03-03-2004, 08:23 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
Default RE: 87 gt 85 mph to 200 mph gauge calibration
What the hell do you need a 200mph speedo for?
jeep45238 is offline
Old 03-03-2004, 12:09 PM
Musthang
Musthang's Avatar
I have the same problem. I was told you should follow the speedometer cable from the dash to the driver’s side of the transmission around there you will find a small plastic colored gear and it is a matter of replacing that gear with the appropriate gear. So the question remains how to find out which gear and where to get it. Maybe you could call a manufacture of a 200mph speedometer and ask if just a gear replacement would solve the problem. I need the same information so pass it on if you find out. Oh, Jeep45238 the answer is because it looks cool. Not to mention what good does an 85MPH speedometer do if you are going 115MPH but maybe you car doesn’t do that.
Musthang is offline
Old 03-03-2004, 01:17 PM
Milky
Milky's Avatar
Look in the forums, someone wrote out all the different gears and colors you need. I think vfast wrote it but I'm not sure. just replace the gear and becareful with the needles...
Milky is offline
Old 03-03-2004, 03:20 PM
TheGmKiller331
I ♥ Acer
TheGmKiller331's Avatar
Look around on the net there are places you can send the speedo off to and have it recalibrated.
Its a little more involved than a new gear in the tranny.
TheGmKiller331 is offline
Old 03-03-2004, 05:57 PM
Quik
Quik's Avatar
its more then just hte gauge overlay. the gearing of the cluster is what you need. most stangs got 140 clusters. you dont need a 200mph unless you plan on running at the saltflats
Quik is offline
Old 03-03-2004, 10:00 PM
VertStangGT86
VertStangGT86's Avatar
Just get a new speedo, they sell them already calibrated for like 140 or so and you can use all the other stock parts. That's much easier then buying and overlay and trying to figure everything else out
VertStangGT86 is offline
Old 03-08-2004, 06:12 PM
pgreder
pgreder's Avatar
Well, first blame the dude who I bought the car from, he liked to pretend 85 on the hwy is 200. All I'm after is a quick way of fixing it. I found out that to calibrate the face plate I have is to use a 30 tooth Speedo gear, 23 tooth is the biggest I believe or seen available. and even then the mileage and trip of the Speedo would be off. So a 89 140mph Speedo is the only real answer for accurate, adjustable, speed and mileage. thanks for all the replies, well most of them.
87' GT T-top.... muscle w/style
pgreder is offline
mtgldr
02-03-2024 09:00 PM
jwog666
12-27-2021 08:09 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
TCStangerv6
10-11-2015 05:57 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: 87 gt 85 mph to 200 mph gauge calibration
