GT Fender emblem removal
Old 04-02-2006, 09:29 PM
DUSTI
DUSTI's Avatar
Default GT Fender emblem removal
I was wondering if ANYONE has removed the GT Fender emblem ?
IF SO, do you have pictures of the (clean) fender and/or the
backside of the emblem - someone told me there are 'studs' on the
backside of the emblem so I want to make sure I can 'cover'
the holes that would leave on the fender.
THANKS for any help !
DUSTI is offline
Old 04-02-2006, 09:44 PM
fairlane292
fairlane292's Avatar
Default RE: GT Fender emblem removal
Of course, hasn't every one? (lol) (3 holes; must be welded; thin metal make sure guy doing it is a pro on light sheetmetal work or the panel is sure to shrink/warp) ...Jim
fairlane292 is offline
Old 04-02-2006, 09:46 PM
chevykiller
I ♥ Acer
chevykiller's Avatar
Most people who have removed them (myself included) are replacing it with some other type of emblem so just leave the holes there and cover them with your new emblem. If you want nothing, then you have to weld and paint.
chevykiller is offline
Old 04-02-2006, 09:47 PM
DUSTI
DUSTI's Avatar
THANKS Fairlane...........what an AWESOME ride you got !
Still baffles me WHY they didn't just 'stick' em on like they used
to do ?! [:@]
DUSTI is offline
Old 04-02-2006, 09:49 PM
DUSTI
DUSTI's Avatar
ORIGINAL: chevykiller
CK,
thanks..............does the emblem just 'pull out' or is there some kind of backing behind it ??
THNKS again !
DUSTI is offline
Old 04-02-2006, 09:54 PM
mauiboy
mauiboy's Avatar
Adhesive tape, fishing line works good...
mauiboy is offline
Old 04-02-2006, 09:55 PM
chevykiller
I ♥ Acer
Can't answer that one cause mine came with the roush emblems. They had studs too but they're was no backing on them - they were held on by two-sided tape and the studs just slipped into the holes. Simply a matter of 'popping & peeling' them off. Not sure if the GT emblem is the same way...Someone please help him out.[sm=feedback.gif]
Old 04-02-2006, 09:56 PM
chevykiller
I ♥ Acer
ORIGINAL: mauiboy
Sorry to hijack the thread - but you are going to Knotts next sunday, right? I still want to look at your predator & tunes??
Mark
Old 04-02-2006, 09:58 PM
06GT4RAD
06GT4RAD's Avatar
It is held on with 3M double side tape and to remove it you can do one of of a few things. You can either heat it with a hair dryer and slowly try to remove it. Or you can use Goo Gone and soak the backside of the emblem them slowly remove also get some heavy fishing line say 30lb test and you can get back behind the emblem with it and the Goo gone and simply slide it back begin it to cut the foam/tape. Then after that is done and the emblem is removed use the Goo Gone to remove any residue.
Richard
06GT4RAD is offline
Old 04-02-2006, 10:04 PM
DUSTI
DUSTI's Avatar
THANKS CK & Richard..............great info..........gonna try that this week !
DUSTI is offline
Quick Reply: GT Fender emblem removal
