Ignition Coil Wiring
Old 04-15-2006, 09:52 AM
popper
popper's Avatar
Default Ignition Coil Wiring
I'm looking at my wiring diagram and it shows the distributor wire (the little one that comes out of the base) and the other wire that comes along the driver's side valve cover both go to the coil. But it doesn't tell me which goes to + and which goes to - on the coil. Also, is this all that attaches to the coil, besides the plug wire to distributor?
Thanks,
Rich
popper is offline
Old 04-15-2006, 11:39 AM
farseek1
farseek1's Avatar
Default RE: Ignition Coil Wiring
The( + )connects to the 12v source from the ignition switch,) -) terminal connect to the distributor, there maybe a tach wire in the harness, if so this also connects to the ( -) side of the coil.
ORIGINAL: popper
Thanks,
Rich
farseek1 is offline
Old 04-15-2006, 01:11 PM
6mustang6
6mustang6's Avatar
Well, ACtually, most likely, unless it has been changed, you dont have 12 volts running to the coil. IT has a resistor wire, which lowers the voltage. I bypassed mine when i installed the pertronix.
6mustang6 is offline
Old 04-15-2006, 11:39 PM
farseek1
farseek1's Avatar
ACTually you are right, but my crystal ball wasn't working to know what he was installing, Thought he
was asking what wires go to the coil.
farseek1 is offline
Old 04-16-2006, 12:05 AM
6mustang6
6mustang6's Avatar
well yeah. It didn't really matter, but i just wanted him to know it. It could come in handy one day, but you were still right, it comes from the switch to the coil. Ta Da.!! lol
Old 04-16-2006, 11:58 AM
Soaring
I ♥ Acer
Soaring's Avatar
You have three wires hooked up to the coil. The - (black) wire goes to the ground inside the dizzy, and the + (red) goes inside the dizzy to hook up to either the points or Pertronix. The other wire comes from the switch, and is hooked up to the + side of the coil.
Soaring is offline
Old 04-16-2006, 04:22 PM
popper
popper's Avatar
OK, got it. Thanks!
popper is offline
Old 04-17-2006, 12:13 AM
6mustang6
6mustang6's Avatar
ummmm Glen. MY coil only has two wires, and has never had anymore then that. i have the wire running from the switch to the coil. Then the wire( i installed) from the switch to the pertronix. Then you have the negative going to the dizzy. IF you remember, if you hook the pertronix up to the coil, it may not work due to the voltage is lower then 12 volts.
Old 04-18-2006, 11:49 AM
ndw13
ndw13's Avatar
I've got my Pertronix hooked up to my Accel super coil....I haven't had any problems thus far but thanks to a broken water pump mounting bolt....she's not running either
ndw13 is offline
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
Dathan
10-05-2015 05:52 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Ignition Coil Wiring
