Old 10-23-2015, 12:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Lighting Guides
Print Wikipost
Replace Tail Light Bulbs
Old 04-29-2006, 12:23 AM
indy042
indy042's Avatar
Default Replace Tail Light Bulbs
Hey,
I searched for this topic, but I came up empty. If it has been discussed, my apologies... I have a 99 GT and a bulb burned out in the tail lights. In the owners manual, it said take it to the shop. (Phhhtttpth, whatever...) Would anyone be able to share how to remove the tail light lenses? I figure you have to go thru the trunk, but I don't want to guess. Any help would be greatly appreciated!
-I
indy042 is offline
Old 04-29-2006, 12:32 AM
St4ng07
St4ng07's Avatar
Default RE: Replace Tail Light Bulbs
Just get a haynes manual like 15$. Helps in the long run....I would try to help you but IDk how to do it either.
St4ng07 is offline
Old 04-29-2006, 06:03 PM
mlax
mlax's Avatar
It's easy. There are about 6 bolts that stick thru in your trunk undo them and the whole assembaly comes out. Once that is donr just remove the light socket from the back and change the bulb.
mlax is offline
Old 04-29-2006, 07:25 PM
rbstang
rbstang's Avatar
this should help some...
http://mustangworld.com/ourpics/fcar/cobralights.htm
rbstang is offline
Old 04-30-2006, 12:21 PM
indy042
indy042's Avatar
Thank you all for the help! I'll knock it out shortly.
-I
indy042 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
JonnyBlazeGT
11-03-2015 01:10 AM
kdryan
08-21-2015 04:01 PM
chain
08-17-2015 08:52 AM
philster0306
08-10-2015 11:33 AM
Quick Reply: Replace Tail Light Bulbs
