351 Mustang
Difference between a 351w and a 351c
Old 05-12-2006, 05:50 PM
347Stroker Cougar
347Stroker Cougar's Avatar
Default Difference between a 351w and a 351c
i'm buying a 351 block from our school mechanic but he doesn't know if it's a 351w or a 351c.
What's really the difference between the two? which is better? which would be better for making a 408 stroker.
Thanks, Taylor.
347Stroker Cougar is offline
Old 05-13-2006, 04:20 AM
myshifter
I ♥ Acer
myshifter's Avatar
Default RE: Difference between a 351w and a 351c
ORIGINAL: 347Stroker Cougar
Thanks, Taylor.
They are 2 totally different families. The cleveland is old school and unless you have 10-15k to build a serious cleveland then stay away. You can tell a cleveland a mile away by noticing the thermostat bolts directly to the block. they are notoriously thin, 30 over bore means you gotta search through dozens of core blocks to find one with out much core shift. Just stay away, more than likely your getting a winsor. Clevelands are a rare bird nowadays. They are an awesome engine if you have the money and like to play around. Im sure your getting a winsor
myshifter is offline
Old 05-13-2006, 04:30 AM
5.0wot
5.0wot's Avatar
I thought the cleveland was a strictly truck block w/ slanted bores to produce MASSIVE torque...........Was I miss-imformed?
5.0wot is offline
Old 05-13-2006, 12:47 PM
myshifter
I ♥ Acer
myshifter's Avatar
ORIGINAL: 5.0wot
Yes, you were. The cleveland 4V that everyone uses for restorations make absolutely no low end torque. They can be built to turn massive rpm but lack bottom end torque big time, due to Fords thinking of bigger is better. Go look at an intake runner on a 4V cyclinder head, you could almost fit a tennis ball in the port. That kills low end torque massively. There is absolutely no velocity at low rpm. Not to mention a host of other problems with the cleveland.
mustangheaven
01-03-2016 11:20 AM
Dokilar
15
10-16-2015 08:13 PM
mustangheaven
10-07-2015 10:23 AM
guitarman376
09-30-2015 05:54 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: Difference between a 351w and a 351c
