Trick Flow High Port SBF Heads ?
Old 06-20-2006, 04:14 PM
89 mustang
89 mustang's Avatar
Default Trick Flow High Port SBF Heads ?
ok here's my question, dose any one here have the Trick Flow High Port SBF Heads on a 302 or 306 motor? I need to know the push rod length
89 mustang is offline
Old 06-20-2006, 04:19 PM
schwindty
schwindty's Avatar
Default RE: Trick Flow High Port SBF Heads ?
I am going to buy some get a pushrod length checker and be sure the first time every application is different pending on head gaskets and such!
schwindty is offline
Old 06-20-2006, 06:41 PM
50mikey
50mikey's Avatar
Are you buying these heads? if so they come with a parts list of what you will need, like lengths of pushrods depending on the roller rockers your using, what plugs you'll need to get. everything
If you got them used or just dont have that sheet I would call em, they could tell you pretty quick
50mikey is offline
Old 06-30-2006, 04:05 AM
89 mustang
89 mustang's Avatar
yea got them used, thanks for the info
uedlose
The Racers Bench
10-01-2015 08:31 PM
69Volunteer
09-30-2015 10:39 AM
mungodrums
09-28-2015 10:54 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Trick Flow High Port SBF Heads ?
