86-88 GT Fuel Pressure Regulator Location?
Old 07-02-2006, 11:07 AM
gmsceo
I ♥ Acer
gmsceo's Avatar
Default 86-88 GT Fuel Pressure Regulator Location?
Hello. I'm trying to install an adj. fuel pressure regulator on my speed density '88 GT because the idle pressure is sitting at 44-46psi, idles like s#@t, smells rich, and sometimes stalls when you come to a stop or put it in park. It runs awesome once you get rolling and at WOT though. I was thinking it needs to have the idle fuel pressure lowered to cure the problem, but I honestly don't see the stock FPR! Maybe I'm looking too hard, or just an idiot, but I don't see it. Any help would be appreciated!
gmsceo is offline
Old 07-02-2006, 11:37 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: 86-88 GT Fuel Pressure Regulator Location?
Pass side of the motor towards the back under the egr valve. Has a vacuum line going to it.
PRO50SC is offline
Old 07-02-2006, 03:23 PM
Joel5.0
Joel5.0's Avatar
This might help.....
Joel5.0 is offline
Old 07-02-2006, 05:18 PM
Twister
Twister's Avatar
if it is that rich, I doubt it is the FPR, when they fail, the preasure usually drops. It sounds like it is in open loop, so, look at your MAP sensor, a vacuum leak, or a pinched vacuum line. I have had both a FPR fail, and a MAP sensor fail.
Twister is offline
Old 07-02-2006, 05:35 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Joel5.0
Joel to the rescue!! You da man
PRO50SC is offline
svfetter
10-05-2015 11:39 AM
LiquidDrink
09-29-2015 10:06 AM
foxtrot
09-29-2015 06:32 AM
StalkerGT
09-25-2015 02:41 PM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: 86-88 GT Fuel Pressure Regulator Location?
