Engine serial number
Old 07-07-2006, 08:49 PM
Zero 16X
Zero 16X's Avatar
Default Engine serial number
Hello. I'm not really smart when it comes to car tech but im trying to learn. But I have a 1997 Gt mustang i bought off the lot a day after it arrived this past december. Ive been told its 4.6 DOHC but also that DOHC's are cobra engines. Can someone give me some info on this and where to find the engine serial number. Thank you.
Zero 16X is offline
Old 07-07-2006, 09:02 PM
justingt
justingt's Avatar
Default RE: Engine serial number
if it is a GT then it is not a Dual Over Head Cam Engine. The reason for this is because it has 1 intake valve and 1 exhaust valve per cylinder which requires only 1 cam over each of the 2 rows of 4 cylinders. That makes it a Single Over Head Cam Engine. A DOHC has 2 intake valves and 2 exhaust valves for each cylinder which requires 2 cams over each of the 2 rows of 4 cylinders. I hope that wasnt too confusing for you. If you wanna make things easier just take a pic of your engine and post it. For most people on this forum it will be easy to tell if it is SOHC or DOHC.
justingt is offline
Old 07-07-2006, 09:15 PM
Zero 16X
Zero 16X's Avatar
Cool Ill do that when i get my pic card back. But can you tell me where the serial numbers are for both
Zero 16X is offline
Old 07-07-2006, 10:11 PM
Zero 16X
Zero 16X's Avatar
so no one can tell me where it is, or just dont care?
Zero 16X is offline
Old 07-07-2006, 10:25 PM
stang2000
stang2000's Avatar
use the vin number to find out. You can enter the vin at www.carfax.com. It'll specify what engine it has under type. Then you'll know, UNLESS someone change the motor, and unfortunately I don't know where that serial number would be.
stang2000 is offline
Old 07-08-2006, 12:39 AM
Zero 16X
Zero 16X's Avatar
yeah i did that but it said it was a SOHC but I know its a DOHC. I just need to know where the serial number is so i can make sure maybe track it perhaps.
Zero 16X is offline
Old 07-08-2006, 12:42 AM
justingt
justingt's Avatar
as soon as u post a pic youll be told fairly quickly prolly by about 5 people whether its DOHCor SOHC...what makes you so sure its DOHC
justingt is offline
Old 07-08-2006, 08:47 PM
Zero 16X
Zero 16X's Avatar
im not sure. : / Thats why Im trying figure out. Ive been told. Just trying to figure out the facts. As far as I would guess i would think its a normal gt. The guy before me was a Marine so he had money to do stuff to it. It has some parts on it but I dont know.
Zero 16X is offline
Old 07-08-2006, 08:59 PM
GodAmGT00
GodAmGT00's Avatar
Should be stamped on the side of the block. I can't remember which side it is...
Take a picture of the engine, and post it here. I guarantee you w/ in 30 seconds, someone will be able to positively identify the engine type and any other modifications done to it...
JT
GodAmGT00 is offline
Old 07-08-2006, 09:57 PM
Fryguy22
Fryguy22's Avatar
Its probably a SOHC but who knows. Take a pic, your question will be answered.
Fryguy22 is offline
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
tj@steeda
Steeda Autosports
09-01-2015 08:16 PM
Quick Reply: Engine serial number
