Gear Oil Change on a 94 5.0
Old 07-08-2006, 07:37 PM
cepowers18
cepowers18's Avatar
Default Gear Oil Change on a 94 5.0
I was actually wondering the same thing as LOUDexhaust about where to jack up the car, but I also had a few questions about the gear oil change on a 94 5.0.
Is it better to jack up the car, or is it OK to back it onto ramps when changing gear oil? Also, does anyone know where exactly the plug is to put the oil back in the rear end? I understand that the basic steps are unbolting the cover and draining out the oil, looking for metal shavings / cleaning up a bit, and replacing the cover with silicone around the edges, but I can't find the plug on my Stang
Any help on this process is much appreciated!
cepowers18 is offline
Old 07-08-2006, 07:44 PM
lookinforastang
I ♥ Acer
lookinforastang's Avatar
Default RE: Gear Oil Change on a 94 5.0
ah i just replied in the jack thread
make some ramps out of bricks or whatevers available
lookinforastang is offline
Old 07-08-2006, 07:58 PM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
just jack it up and put jack stands under the axle housin, out by the wheels. the fill plug will be a 3/8" drive plug. there wont be a bolt head on it. just stick the end of a 3/8" extension in it with a rachet.
FiveLiterRiceEater is offline
Old 07-08-2006, 09:51 PM
cepowers18
cepowers18's Avatar
Ok, so can anyone tell me exactly where this fill plug is?? I've searched for damn near 30 minutes for the thing and can't locate it.
I'm going to the track tomorrow to run my Stang, and I wanted to change my gear oil b/c it's been over 1,000 miles since my 3.73 gear/rear end install. Will it hurt my car if I run tomorrow, or should I change the gear oil first?
Old 07-08-2006, 11:56 PM
cepowers18
cepowers18's Avatar
Anyone?
Old 07-09-2006, 01:41 AM
Bad Karma
Bad Karma's Avatar
There is a Check/Fill plug only on the top/front of the axle, driver side on Fords. Facing the drivers' side. You may have to take a small screwdriver and get the dirt out before taking it out to prevent stripping and/or to see the damn thing. 3/8's ratchet w/3" extension is correct.
There is no drain plug on it. You can replace the rear gasket or find a vaccuum pump to take it all out through the Check/fill plug.
That's the way we do it at the Dealership.
-Ivan
Bad Karma is offline
Old 07-09-2006, 01:49 AM
FiveLiterRiceEater
it looks like this
Old 07-09-2006, 01:50 AM
Bad Karma
Bad Karma's Avatar
ORIGINAL: FiveLiterRiceEater
it looks like this
+fucting1
Good job,
Ivan
Old 07-09-2006, 02:13 AM
cepowers18
cepowers18's Avatar
Yeah, I have yet to find that stupid thing. Thanks for the picture though. Karma - you say it's on the axle itself? I've looked everywhere for it!
I plan on draining the oil by taking the differential cover off, and then obviously filling it via the fill plug.
Should I be running my car at the track tomorrow given that I haven't changed the gear oil yet?
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
Cin K
08-31-2015 07:31 AM
landomar2014
08-17-2015 04:27 PM
OBleedingMe
08-08-2015 12:02 PM
Quick Reply: Gear Oil Change on a 94 5.0
