Sn-95 (94-98) V6 Mod List
Old 09-04-2006, 01:02 AM
jthorn9
The Godfather
jthorn9's Avatar
Default Sn-95 (94-98) V6 Mod List
OK, I just spent 3 hours making this list, but here is a list for all of you that wanted to know what you can do to your sixer, a good place to get it, and the types of pruducts out there. Now there are way more mods than this list such as sound, body kits, interior dress up, engine bay dress up, and stroker kits that I didn't include, but this should give you a good idea as to what's out there. Boy do I want a a contributer tag for this one.
Air Intake
1.) MAC Cold Air Intake $170 @ autobadges.com
4.) 80mm Cobra MAF set to 24lb injectors
5.) 56mm BBK Throttle Body $249 @ V6mustangstuff.com
Engine
1.) ASP 25% Size Reduced Crank Pulley $72 @ autobadges.com
2.) Billet Aluminum Water Pump Pulley $65 @ rpmoutlet.com
3.) ASP Underdrive Pulley Belt $35 @ autobadges.com
4.) Diablo Predator Tuner 96-04 $399 @ hillbankmotorsports.com
5.) BBK Chrome Valve Covers $329 Silver $199 @ hillbankmotorsports.com
6A.) Stage 2 (AUTO) Powerpack $1725 @ supersixmotorsports.com
6B.) Stage 2+ (MANUAL) Power Pack $1950 @ supersixmotorsports.com
6C.) Stage 2+ (AUTO W/STALL) Power Pack $1950 @ supersixmotorsports.com
6D.) Stage 3 (FORCED INDUCTION) Power Pack $2375 @ supersixmotorsports.com
6E.) Basic Split Port Intake Swap Kit $720 @ rpm-mustangs.com
6F.) 99+ Stage 2 (AUTO) Powerpack $1800 @ supersixmotorsports.com
6H.) 99+ Stage 2+ (MANUAL) Power Pack $2200 @ supersixmotorsports.com
6I.) 99+ Stage 2+ (AUTO W/STALL) Power Pack $2200 @ supersixmotorsports.com
6J.) 99+ Stage 3 (FORCED INDUCTION) Power Pack $2350 @ ssms^^^
6K.) Split Port Swap Gasket Kit (no intake or heads) $310 @ rpm-mustangs.com
8.) 24lb Fuel Injectors $279, 30lb $275, 42lbs $359 @ jegsperformance.com
9.) Stud Mount Adjustable Roller Rocker Arm Kit $495 @ supersixmotorsports.com
10.) Cam Thrust Spacer Roller Bearing Kit $150 @ supersixmotorsports.com
11.) Spring Retainer Kit $225 @ supersixmotorsports.com
12A.) Forged Stock Internals $1200 @ supersixmotorsports.com
12B.) Forged H Beams W/ 351W Rods $1600 @ supersixmotorsports.com
13.) BBK Fuel Pressure Regulator $109.99 @ brothersperformance.com
14.) BBK 56mm Throttle Body $257.99 @ hillbankmotorsports.com
Forced Induction
1.) Nitrous Oxide approx $500 @ jegsperformance.com and many others
2.) Vortech Supercharger approx $3500, see vortechsuperchargers.com for info.
Ignition
1A.) Red/Blue/Yellow 9mm Spark Plug Wires $70 @ autobadges.com
1B.) Chrome 8mm Spark Plug Wires $100 @ autobadges.com
2.) see msdignition.com for the rest of your ignition needs
Exhaust
1A.) JBA Silver or Titanium Short Tube Headers $640.97 @ hillbankmotorsports.com
1B.) JBA Short Tube Headers $460.72 @ hillbankmotorsports.com
1.C) JBA Chrome Short Tube Headers $349.99 @ brothersperformance.com
2A.) 2.5” V6 O/R X-Pipe see pypesperformance.com
2B.) MAC 2.5” V6 O/R H-Pipe $160.50 @ hillbankmotorsports.com
2C.) 2.5” V6 High Flow Catted X-Pipe see pypesperformance.com
2D.) 2.5” V6 High Flow Catted H-pipe see pypesperformance.com
3A.) Magnaflow 2.5” GT Cat-Back Dual Exhaust $469.99 @ brothersperformance.com
3B.) Borla 2.5” GT Cat-Back Dual Exhaust $699.99 @ brothersperformance.com
3C.) Bassini 2.5” GT Cat-Back Dual Exhaust see bassini.com
3D.) Flowmaster 2.5” GT Cat-Back Dual Exhaust see flowmaster.com
4.) MIL Eliminators (for O/R systems only) $61.95 @ hillbankmotorsports.com
Drivetrain
1A.) Ford Racing Posi-Traction 7.5” Differential $199 @ v6mustangstuff.com
1B.) See drivetrainspecialists.com for more durable options
2A.) 3.73 Motive Performance Plus Gears $ 149.99 @ mustangtuning.com
2B.) 4.10 (Moderately Moded Apps Only) Motive Performance Plus Gears $149.99 mt
2C.) 3.73 Ford Racing Gears $199.99 @ v6mustangstuff.com
2D.) 4.10 (Moderately Moded Apps Only) Ford Racing Gears $209.00 @ v6ms
3.) Motive Bearing Kit $74 @ mustangtuning.com
4.) 23 Tooth Speedo Corrector -
Transmission Auto
1.) High RPM Stall Torque Converter see mustangsunlimted.com
2.) Shift Kit see mustangsunlimted.com
Transmission Manual
1.) Steeda Tri-Ax Short Shifter $179 @ autobadges.com
2.) Shifter Gasket Set $9 @ autobadges.com
3A.) Spec Stage 2 Clutch $333.95 @ mustangsunlimited.com
3B.) Spec Stage 2+ Clutch $399 @ mustangsunlimited.com
3C.) Spec Stage 3 Clutch $499 @ mustangsunlimited.com
Suspension
1.) Steeda Caster Camber Plates $229.95 @ autobadges.com
2.) Steeda Lower Control Arms $295.95 @ autobadges.com
3.) Steeda upper Control Arms $295.95 @ autobadges.com
4.) Steeda Lower Subframe Connectors $89.95 @ autobadges.com
5.) Eibach Pro Spring Kit $224.95 @ autobadges.com
6.) Tokico D-Spec Shocks $629 @ autobadges.com
7.) Ford Racing (Cobra) Break Kit $819.88 @ mustangsunlimited.com
8.) 17” or 18” Rims see tirerack.com
jthorn9 is offline
Old 09-04-2006, 01:06 AM
redass02gt
EXTREME Moderation
redass02gt's Avatar
Default RE: Sn-95 (94-98) Mod List
you forgot 78039873892340 other parts.
redass02gt is offline
Old 09-04-2006, 01:36 AM
kintek
kintek's Avatar
Default RE: Sn-95 (94-98) V6 Mod List
nice list man, check my post i got in here about 10 down maybe more, says which would be better or something like that, let me know. I cant get any other reponse thanks. Later
kintek is offline
Old 09-04-2006, 01:38 AM
mustangman02232
mustangman02232's Avatar
nice list maybe you can get a sticky
mustangman02232 is offline
NeoTokyo
03-11-2017 08:10 PM
92hatchLX
07-06-2009 10:36 AM
OJMiles
10-06-2006 12:57 PM
HRnB
04-10-2006 11:42 PM
TheGmKiller331
02-18-2004 12:55 AM
Quick Reply: Sn-95 (94-98) V6 Mod List
