How to get a 302 450HP
Old 09-24-2006, 01:32 AM
mn5285
mn5285's Avatar
Default How to get a 302 450HP
I bot a 1970 Mustang it came with a 302 I whont to get 450HP? so I woud like to now the best heads and intake and corb to get? Thanks [&:]
mn5285 is offline
Old 09-24-2006, 01:58 AM
atomsk680
atomsk680's Avatar
Default RE: How to get a 302 450HP
reality check.
why would you NEED 450HP? Street usage? dragstrip? you will kill yourself
well to answer your question new heads, better cam, intake, bigger carb, longtube headers, xpipe, good mufflers. but of course, with the cam, you could get it as high as needing 93 Premium only or even higher octane racing gasses. and you will probably get 2mpg on a good day.
better answer. buy a 351cleveland block, get a mild cam, intake, a good sized carb, longtube headers and xpipe
atomsk680 is offline
Old 09-24-2006, 05:05 AM
deadcarnahans
deadcarnahans's Avatar
You are insane.
Start with the rearend and suspension. 2-3 thousand should cover that.
Then 2 thousand for a tranny.
Then see how much money you have left to build an engine.
deadcarnahans is offline
Old 09-24-2006, 05:33 AM
Colorado_Mustang
Colorado_Mustang's Avatar
Build up a 7.5:1 short block with forged internals. Find some 2.02/1.60 heads, fully ported and polished. Use a roots-style blower as your intake. Call Comp Cams for a suggested cam. Install nitrous system.
But, that'll get you a bit more than 450hp. You could build a NA 450hp 302, but it's ability to run that power level on pump gas will be questionable.
ORIGINAL: mn5285
Colorado_Mustang is offline
Old 09-24-2006, 02:39 PM
THUMPIN455
THUMPIN455's Avatar
If its a drag only ride, then its easier. 13:1 Compression, a huge cam and plenty of airflow. Making it driveable is entirely different, a 302 at that level will be ragged and barely driveable, it wont like to idle and will overheat even with a huge radiator and dual fans while sitting in traffic.
I would suggest a 347 stroker and a blower, afr heads, and make sure the crank, rods and pistons are all forged. It should only run you about $15,000 to build it. Then you need the 9" rear that is beefed to handle it, and a built trans. A small block C6 is tough to find but that would be the auto you need.
302 blocks tend to break right down the middle at around 550-700hp in boosted applications so you might end up with an expensive pile of junk parts after a few passes.
If it were my car and I wanted MEGAPOWA.. I would drop in a Cleveland or a 460 with ported aluminum heads. Its easy to get 500hp from a 460 even with just the Edelbrock heads. It will even fit in a 70 Mustang.. sorta...
Just so you know its tough to have 1 horse per cubic inch in a streetable small block, but even 300 or 350hp is much easier to do and will still scare the bejezus out of you and some of your friends.
THUMPIN455 is offline
Old 09-24-2006, 11:02 PM
JBradley500
JBradley500's Avatar
just buy a crate 347...you can get 450+ hp
JBradley500 is offline
Old 09-25-2006, 01:07 AM
mustanglover66
mustanglover66's Avatar
We have a 302 block 347 with blower sitting in your shop now puting out 530 Hp and around 500 Ft/lbs of torque. you can get a simialar engine from us for less then $8,000 with a 1 year 12,000 mile waranty. Your standard 347s put out 400+ hp
I forgot to add thats on pump gas
[IMG]local://upfiles/33399/D7F1C5B5154D48CBBA1C0B2BD26FB763.jpg[/IMG]
mustanglover66 is offline
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
69Volunteer
09-30-2015 10:39 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: How to get a 302 450HP
