Transmission Noise When COLD??
Old 09-24-2006, 08:23 PM
MarineNCOIC
MarineNCOIC's Avatar
Default Transmission Noise When COLD??
What's up... new to the forum, but not new to Mustangs. Just got a 2003 Mach 1. Been driving it for about a month now but i started to notice when i start the car first thing in the morning there is this awful metal on metal grinding noise that slowly dies down in about 5 minutes. If i tap the clutch pedal it gets worse. Once at operating temperature, no noises at all. I was thinking throw out bearing at first, but this is acting the opposite of any bad throw out bearing I've had to replace. It usualy goes away with pedal pressure. Kinda stumped... maybe pressure plate? The noise is getting worse in the mornings or when the engine is cold. I've been driving it pretty conservatively lately, but no driveability issues what so ever, clutch doesnt slip, jerk, or anything. Well that about sums it up. Great first post, huh? Thanks in advance for any input.
MarineNCOIC is offline
Old 09-24-2006, 10:39 PM
MarineNCOIC
Default RE: Transmission Noise When COLD??
10 hits... no ideas? I know theres some trans gurus out there.
Old 09-24-2006, 11:41 PM
OV10stang
OV10stang's Avatar
Does it make the noise with the clutch pedal pushed all of the way in? Mine sometimes makes a little noise when cold in nuetural at idle and goes away as soon as I push the pedal in. But then again, I've got almost 80k on mine now.
OV10stang is offline
Old 09-25-2006, 03:20 AM
MarineNCOIC
The noise is worse with the clutch pedal all the way in rather than just resting my foot on it. It makes the noise regardless of gear. I've drove once or twice without letting the noise go away first and it seems the noise is in tune with engine rpm. I dunno if this helps any.
Old 09-25-2006, 03:58 AM
boss281
boss281's Avatar
i have an 03 gt and my trans makes a weird noise in 5th when its cold not sure why............
boss281 is offline
Old 09-25-2006, 10:58 AM
mattmoto441
mattmoto441's Avatar
its the throw out bearing mine is doing the same thing and i need to get it fixed to [:@]
mattmoto441 is offline
Old 09-25-2006, 11:43 AM
orangedrp007
orangedrp007's Avatar
i've been having the same problem. i tried to get a few people to listen to it also but if its not in the mourning then it doesn't make the noise. do i need to take it to the ford dealer? how much will it cost?
orangedrp007 is offline
Old 09-25-2006, 02:19 PM
performance_stangs97
performance_stangs97's Avatar
Sounds to me like your pressure plate or clutch face. If you replaced the throw-out bearing, i would have went ahead and did some work on your pressure plate as well. If its chirping you hear, then that is your throw-out bearing, when u put pressure on the clutch, the chirping will quit. My 97 GT does the same thing
performance_stangs97 is offline
Old 09-25-2006, 07:55 PM
MarineNCOIC
I've replaced T/O bearings before... it's definately not the normal chirping noise it's more metal on metal like a die grinder. First time I heard it i didnt know it was my car, i thought someone was cutting 2x4s in the distance. It actually gets worse with pedal load. I was leaning toward pressure plate, the clutch is tight and doesnt slip whatsoever. Might as well replace the whole set up while I'm at it though. Any reccomendations for clutch/flywheel/throw out/pilot bearing combo?
AmericanMuscle4.6GT
11-10-2015 02:06 PM
04stangman
09-26-2015 09:33 AM
ccdguy
09-19-2015 05:20 PM
04stangman
09-17-2015 01:45 PM
Quick Reply: Transmission Noise When COLD??
