Engine VIN code X?
Old 09-29-2006, 02:11 AM
BatMobile00
BatMobile00's Avatar
Default Engine VIN code X?
What are the engine VIN code differences on a 2000 mustang? Mine is "X" but what is "W" and "6" and what there a "Y" or "H" i think i saw?
BatMobile00 is offline
Old 09-29-2006, 02:35 AM
BatMobile00
Default RE: Engine VIN code X?
no one knows............?
Old 09-29-2006, 10:01 AM
stang2000
stang2000's Avatar
First 3 VIN Position's - World manufacturer identifier
1FA — Ford, USA, passenger car
1FD — Ford, USA, incomplete vehicle
Fourth VIN Position - restraint system type code
L — Active safety belts — all positions, first generation air bags.
F — Active safety belts — all positions, second generation air bags.
Fifth through Seventh VIN positions indicate vehicle line, series and body type
P40 — Two-door coupe.
P44 — Two-door convertible.
P42 — Two-door coupe, GT.
P45 — Two-door convertible, GT.
P46 — Two-door convertible, Cobra.
P47 — Two-door coupe, Cobra.
Eighth VIN position is the engine displacement and number of cylinders code.
V — 4.6L, EFI (DOHC), eight cylinder.
X — 4.6L, EFI (SOHC), eight cylinder.
4 — 3.8L, EFI, six cylinder.
Ninth VIN position is the check digit code (0-9)
Tenth VIN position is the model year code
Y — 2000
Eleventh VIN position is the assembly plant code
S — Pilot Plant, Allen Park, Michigan (USA).
F — Dearborn, Michigan (USA).
Last six VIN positions are the production sequence number
[hr]
This is pulled from a 2000 Mustang VIN Reference Guide, so it pertains to all 2000 Mustangs.
stang2000 is offline
Old 09-30-2006, 02:35 AM
mlang381
mlang381's Avatar
the x means the engine came from windsor, canada the other code came from romeo, michigan
mlang381 is offline
Old 09-30-2006, 03:45 AM
HYBRED
HYBRED's Avatar
There's a lot of discrepancy as to whether the engine code denotes a Windsor or a Romeo block. I've heard all 99-00 GT's had Windsor blocks, but I haven't found any evidence of this. An easy check is to count the driver's side cam cover bolts - 11 bolts means a Windsor, 9 (I think) means a Romeo.
HYBRED is offline
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
zachary1988
09-04-2015 03:04 PM
Quick Reply: Engine VIN code X?
