Anyone know how or if its possible to adjust your shifter cable?
Old 10-14-2006, 01:25 PM
Wick001
Wick001's Avatar
Default Anyone know how or if its possible to adjust your shifter cable?
Does anyone know how or if its possible to adjust your shifter cable on an automatic? My car is like 1 off what it says on the shifter. and i cant shift it into 1st gear...
Wick001 is offline
Old 10-14-2006, 01:55 PM
samseed101
samseed101's Avatar
Default RE: Anyone know how or if its possible to adjust your shifter cable?
very easy to do. First, you need to get some ramps or something to get under the car. Then get the car on the ramps, chock the tires, put on e-brake etc. To make it easier, I put the car shifter in neutral. Then I go underneath the car and look on the driver's side of the tranny. You will see a single bolt that's holding the cable to the side of the tranny. Loosen the bolt so that the bracket in the cable can freely slide back and forth. The cable is bolted to a little lever. The lever is what changes your gears. Pull it all teh way back and that should be first. Then slowly move it forward until you hear it click. Every click will be one gear. Count the number of "clicks" neded until you get the tranny itself in neutral. Then take the slack out of the cable by pulling it slightly (careful not to pull it too hard or your shifter will move forward to.) After that, tighten the bolt back up and you're done. Now both the tranny and the shifter should bew in neutral.
I hope that makes sense. If not, I can run outside and snap a quick photo of what I mean.
samseed101 is offline
Thunderball
15
11-22-2015 11:49 PM
kevsgt
10-09-2015 10:12 PM
Explosive
10-02-2015 07:45 AM
winner99
09-30-2015 07:04 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Anyone know how or if its possible to adjust your shifter cable?
