volume knob problem!
Old 10-27-2006, 01:03 AM
handyandy
handyandy's Avatar
Default volume **** problem!
I posted this in the audio/video electronics section, no one seems to be too active over there, maybe someone can help me here. Sorry. Thank you.
When I try to turn my volume down quickly, or some times not quick at all, my volume will actually go up! It's really annoying! If someone is trying to call me, and I have to turn down my volume for some other reason fast, and I turn it down, it'll shoot up even louder! Does anyone else have this problem? How can I fix it?
handyandy is offline
Old 10-27-2006, 01:05 AM
mvr
mvr's Avatar
Default RE: volume **** problem!
sounds like a good reason to buy a really nice aftermarket deck
mvr is offline
Old 10-27-2006, 01:35 AM
Colorado_Mustang
Colorado_Mustang's Avatar
I just hit the mute button or push in on the volume button....both ways work really well.
Colorado_Mustang is offline
Old 10-27-2006, 01:36 AM
koumiss45
koumiss45's Avatar
It's because you have 4.10's. It has something to do with the speedometer electrical signal, I don't know why it does this but it does. Nah, not really, lol but I am with matt get a nice aftermarket deck and enjoy it. If you dont want to worry about the volume issue, get some lm 2's and a off road h pipe and say screw it, you wont be able to hear anyway.
koumiss45 is offline
Old 10-27-2006, 02:22 AM
rjgstang
rjgstang's Avatar
dude, mine does the same thing and also does not load/eject cd's properly causing much frustration!![:@]
rjgstang is offline
Old 10-27-2006, 03:15 AM
BlOwNsNaKe
BlOwNsNaKe's Avatar
You all must be talking about the Mach 460! They all do that as well as mine. You are not alone my friend so you have 3 choices. sing to yourself, live with it, or time for an upgrade!
BlOwNsNaKe is offline
Old 10-27-2006, 03:26 AM
mvr
mvr's Avatar
ORIGINAL: rjgstang
GAH, I HATE THAT!! [:'(]
mvr is offline
Old 10-27-2006, 10:49 AM
handyandy
handyandy's Avatar
lol yeaaaaaa. oh well I just listen to my exhaust most of the time. Even more once, i get a midpipe.
Old 10-27-2006, 11:48 AM
AJ06GT
AJ06GT's Avatar
It's just in the electronics of the **** itself. It's not a specific issue of one headunit really. You will encounter this a lot on all different kinds of *****, turn them too fast and they go the opposite direction. I don't know for sure, but I have some ideas of why exactly it happens in electronics terms, but I wont bore you with that. Bottom line is you probably aren't going to fix it unless you desolder the volume control and find another one to replace it that's higher quality and resolder that on. That or just live with it or get a new head unit. I'd go for the get a new head unit option. That was one of the first things I did to my car, got an iPod plug and all.
AJ06GT is offline
Old 06-14-2013, 09:56 AM
gumm0712
gumm0712's Avatar
Had the same issue on my 2002 GT. Without dissasembling anything just used a fine nozzel with my air compressor set about 90 psi and simply blew air all around the edge of the **** while rotating back and forth. Did not fix it at first, kept blowing air and rotating for a few minutes and then it was fixed. Must have been dust build up inside the potentiometer.
Hope this saves people some time and money.
Kevin
gumm0712 is offline
Quick Reply: volume knob problem!
