How to spin both tires.
Old 11-02-2006, 08:30 PM
4.0 Stang
4.0 Stang's Avatar
Default How to spin both tires.
What do i need to make both tires spin.
4.0 Stang is offline
Old 11-02-2006, 08:31 PM
randy78045
randy78045's Avatar
Default RE: How to spin both tires.
ORIGINAL: 4.0 Stang
Install a limited differential....
randy78045 is offline
Old 11-02-2006, 08:41 PM
petepete
petepete's Avatar
http://v6mustangstuff.com/05Drivetrain.htm t-lock
petepete is offline
Old 11-02-2006, 09:06 PM
4.0 Stang
4.0 Stang's Avatar
so when I get this done I should probally get new gears put on at the same time. 3.73 or 4.10
Old 11-02-2006, 09:07 PM
randy78045
randy78045's Avatar
ORIGINAL: 4.0 Stang
yep
Old 11-02-2006, 09:53 PM
pperin
I ♥ Acer
pperin's Avatar
Just got my 3.73's and T-lock haven't spun the wheels yet but the gears are nice car pulls good and gets up to rpm's quick from almost all gears! Go 3.73 I have heard alot of guys say that they regret the 4.10's cause they run too highin RPM's at freeway speeds. Mine are fine in 5th.
pperin is offline
Old 11-02-2006, 11:07 PM
DragonPL
DragonPL's Avatar
do you have auto or manual pperin??
DragonPL is offline
Old 11-02-2006, 11:41 PM
Horrific_Ending
Horrific_Ending's Avatar
3.73 gears will fit in the stock rear housing right? or is it just better to just install a T-lock and not upgrade the gears?
Horrific_Ending is offline
Old 11-02-2006, 11:44 PM
28HopUp
MF Administrator
28HopUp's Avatar
ORIGINAL: Horrific_Ending
As long as they are for a 7.5" rear-end. The 3.73's for a 8.8" GT rear will not fit a 4.0L rear housing.
You can add a t-lok and not change your gears, but if you think you may want to change the gears some time down the road, then you should do it all at once and save on labor charges by not having the rear opened up twice.
28HopUp is offline
Old 11-02-2006, 11:53 PM
Horrific_Ending
so bascially you have to buy a GT Rear axle buy a T-lock then the gears?
Quick Reply: How to spin both tires.
