Rear axle misalignment...
Old 11-03-2006, 01:44 PM
GodAmGT00
GodAmGT00's Avatar
Default Rear axle misalignment...
Well, in my quest to figure out why I get such nasty drivetrain vibration, I've gone through a lot of variables, and still haven't been able to pinpoint an exact cause, unless...
Last night, when I was checking out my rear tires, which have been only rubbing on one side (yes, I haven't rolled my fenders yet, so sue me..), I noticed that the Passenger's side sticks out nearly a half inch past the fender... I run to the other side, and notice that my 315/35R17's are actually a half-to-a-whole inch tucked under the fender.. WTF?!?!?!?
SO in my mind, my rear axle is pretty far off from what I believe to be normal. I would have never seen that much of a discrepancy w/ my old tires/rims...
Since I've swapped U-joints, had the rear axle rebuilt, and rebuilt again, complete suspension overhaul, NEW tires/rims, and new tranny mount, I couldn't for the life of me find out what was causing the vibration... Now I think I know..
Now here's the "meat and potatoes." Since panhard bars are used to center the rear axle on the chassis, this sounds like the only approach I have to straighten things out; no pun intended..
Question I have is, since I have a rear-diff girdle, it looks like a panhard may not work. Has anyone else used a panhard bar along w/ a rear diff. girdle w/ success?? Before I make the plunge, I wanna know if it'll work..
TIA
JT
GodAmGT00 is offline
Old 11-03-2006, 04:49 PM
GodAmGT00
GodAmGT00's Avatar
Default RE: Rear axle misalignment...
Okay, so I lied..
The other question that I had was, do any of you other folks notice your rear axle being offset from the chassis?? Oh, and if so, do you get nasty vibration at highway speeds??
I believe mine is a "worst case," scenario, since not only is it misaligned, it's been doing this for a while.. I ruled out the accident I got in, since I had the vibration before that, as far as I could remember at least, since the last diff. rebuild..
Also, how exactly does a panhard bar attach?? I can't for the life of me figure it out, even after looking at pictures..
JT
Old 11-03-2006, 05:04 PM
Tac2cul
Tac2cul's Avatar
i know this isnt a a new edge but may give u an idea...
Tac2cul is offline
Old 11-03-2006, 05:10 PM
GodAmGT00
GodAmGT00's Avatar
Sweet, those pictures rocks.. Almost exactly what I was looking for, w/ the exception of....
It looks like it goes to Driver's side, upper C/A mount, then to Pass. Upper C/A mount, then the torque bar connects it to... itself??
How exactly does this ensure that it centers your axle on the chassis though?? Do I need to get an adjustable version??
Also, is there any true way to align a solid axle?? I've yet to find any type of adjustment that could fix the Yaw of the axle..
JT
Old 11-03-2006, 05:28 PM
Tac2cul
Tac2cul's Avatar
ORIGINAL: GodAmGT00
JT
got no clue bud.... i just found em on another site and posted them....
heres one of the parts
this MAY help
http://www.miracerros.com/mustang/t_suspension.htm
Tac2cul is offline
Old 11-03-2006, 05:40 PM
GodAmGT00
GodAmGT00's Avatar
Wow, that link is awesome.. That just gave me a bunch of info..
I think I was confusing the Panhard w/ the Watts Linkage.. What a duma-s... That was whole reason for asking in the first post if I can use it w/ a girdle, since the Watts Linkage attaches IIRC to the top 3 Diff. cover bolts. I can't do this, since the bolts that hold the girdle are recessed..
Anyway, I'm going to start looking for decent panhard bars which means I should have a set of really nice, almost brand new Granatelli UCA's if anyone's interested..
JT
Old 11-03-2006, 05:54 PM
SVTBill
SVTBill's Avatar
If your alignment is off youll see it in your tires. Look for inside edge wear and/or uneven cupping wear.
SVTBill is offline
Old 11-03-2006, 05:57 PM
Tac2cul
Tac2cul's Avatar
welp glad i could help
Tac2cul is offline
Old 11-04-2006, 10:03 AM
GodAmGT00
GodAmGT00's Avatar
What a pain in my **** this morning..
I had to drive to my Reserve duty, and it's about an hour and a half.. Everything seemed okay, minus the vibration, which wasn't as bad this morning, surprise surprise..
Well, I hit a rotary (or round-a-bout to you other funny folks), and I was probably doing about 50-60, and took the corner well, straighten the car out, and go for about 500 yards, and start smelling gear oil... Son of a bitch..
Part of me thinks that I may have thrown a little too much oil in the axle the other night, but it looks like the leak is coming from the Check valve... I hope this is the case, since it's going to be hard to find a ride home on Sunday night, much less getting the car back almost 100 miles to my house..
The thought of blowing up the car has crossed my mind....
JT
Old 11-07-2006, 01:29 PM
Tac2cul
Tac2cul's Avatar
any update?
Tac2cul is offline
Quick Reply: Rear axle misalignment...
