old block 351w ... new roller block 351w
Old 11-08-2006, 10:28 PM
mustang141
mustang141's Avatar
Default old block 351w ... new roller block 351w
My body works almost done and it's time to put her back together. My problem is this and I would realllllllly appreciate some feedback on this one. I want to stroke a 351 windsor up to a 392. I can get a 1974 windsor block 0.030 over already (slight ridge since rebuild) and probably get away with 0.010 more to end up with a 0.040 over. My builder tells me it's harder to get pistons at 0.040 over than 0.030 over (probably true but so what?). This block is $250.00. On the other hand I can get a F4 roller block (94-97 truck/van roller block) for $400.00. The older block is not roller ready and would have to be drilled. The new block hasn't been bored but is thinner walled but rollered. My goals are to get close to 500 hp out of this thing when it's done. What does a guy do here? I mean pros and cons. Thanks
mustang141 is offline
Old 11-08-2006, 10:32 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: old block 351w ... new roller block 351w
go for the late model block if ur gonna run a roller(ull make more power and if ur gonna build a stroker might as well) the new foller will stand up to abuse fine theres tons of lightning guys running them
rmodel65 is offline
Old 11-08-2006, 11:38 PM
Cannonball888
Cannonball888's Avatar
Can you get 500 HP from 392? I would stroke to 418.
Cannonball888 is offline
Old 11-08-2006, 11:42 PM
JBradley500
JBradley500's Avatar
500 hp from 392?? you can get 500 hp from 302....id go with the roller block...make sure to get a main support.
JBradley500 is offline
Old 11-08-2006, 11:51 PM
mustang141
mustang141's Avatar
http://www.musclemustangfastfords.co...0305_mmwicked/
Apparently this article talks about a 392 stroker getting 500 hp. If I can get kinda close even that would be good. Who knows though? Sometimes these articles can be a bit decieving though I think ... but then ford racing has a 392 stroker that makes I think around 480 hp so should be able to?
Old 11-08-2006, 11:52 PM
mustang141
mustang141's Avatar
Like a girdle you mean? (main support)
Old 11-08-2006, 11:54 PM
mustang141
mustang141's Avatar
By the way nice Mach 1. 428? Lucky guy
Old 11-09-2006, 02:23 AM
4reboy
4reboy's Avatar
For what its worth, my 351w was bored .040 over with no problem, builders didnt' say anything about finding .040 pistons as being a big deal...
4reboy is offline
Old 11-09-2006, 05:40 PM
JBradley500
yeah i mean a girdle on the main caps, and for the best protection besides that, there's a support for your lifter bored (not sure of the name) that will keep the thing in 1 piece.
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
guitarman376
09-30-2015 05:54 PM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: old block 351w ... new roller block 351w
