Trick Flow Intake Install on 95 GT?
Hey I am putting a trick flow street heat intake on my 95 GT. I can see there are 4 oil/vacum skrew in type holes under the trick flow intake. But on my original intake there are only 2. What 2 should I try to hook the lines up to? How should I go about doing this? Anyone with experience with this would be helpful. Thanks
RE: Trick Flow Intake Install on 95 GT?
I know it doesn't answer your question, but let me know how the install goes. I have been told that you have to put a spacer between the upper / lower on an SN95 due to EGR clearance issues. I was also told that there will be clearance issues with the hood too. That's the reason I stayed away from TF. I am curious what your experneice is with it.
I have a spacer and I am pretty sure it will work, I have see many 94/95's with the TFS intake and the stock hood. The stut tower brace may not work, but I will see when I get there.
The kit comes with plugs, you plug 2 outa the 4 holes, and you use the vacuum stems that comes with the kit also. And yes, it does fit under the hood of a sn95.
The stock brace doesnt fit. But they make aftermarket ones that do. I think if the brace will fit over a gt40 intake, it'll fit over a trickflow, so i've heard.
http://froogle.google.com/froogle?q=...oogle&ct=title
I could shut my hood (stock) but I had to adjust it all the way up, and notch the latch on the car to move it up so it could latch. And it still rubbed the paint off of my intake (thats why I painted it). It's just a 5.0 with twisted wedge heads and trick flow street heat intake? I did put prothane engine mounts on when I put the motor in, maybe thats why?
ORIGINAL: samseed101
nope. not the same.
ORIGINAL: CrazyCobraSpeed
juss wondering.. is a cobra intake and a gt40 intake the same think??
The GT40 is a tubular upper and the cobra is all cast together (very similar to the explorer upper). Google them for pics...or look on Ebay.
