Sponsored by: DashLynx
Can you change a V6 to a V8?
Old 11-16-2006, 10:42 PM
Falcon1
Falcon1's Avatar
Default Can you change a V6 to a V8?
Hey guys, this is probably a stupid question, but is it possible to change a V6 to a V8? I found a really nice V6 near me, but I want a V8...I wanna use it till the V6 goes out or something, and put a V8 in, im not sure if thats possible, Is it? Thanks.
Falcon1 is offline
Old 11-16-2006, 11:11 PM
wythors
wythors's Avatar
Default RE: Can you change a V6 to a V8?
It's certainly possible and is done all the time. But, unless you're able to do all the work yourself, the cost will be way more than the finished car will be worth. If you want a V8 car, you're much better off to keep looking for exactly the one you want.
wythors is offline
Old 11-16-2006, 11:14 PM
72MachOne99GT
2010 Blue Ball Award Recipient
72MachOne99GT's Avatar
he got it.. it'd be neat to have an engine swap, but after all the work, and modifications you'd have to make, it'd be much cheaper, and would take ALOT less time to just find a GT from some year, or a 5.0 Fox
72MachOne99GT is offline
Old 11-16-2006, 11:16 PM
Falcon1
Falcon1's Avatar
Yeah, I guess...but I cant find a 1999-2002 V8 w/ 100kish miles, I can only spend 6k max.. so yeah
Falcon1 is offline
Old 11-17-2006, 12:41 AM
7upedition
7upedition's Avatar
doable, seen it doen before, but very time consuming and expensive by the time verything is swapped and figured out, better off with the v8 to start with
7upedition is offline
Old 11-17-2006, 01:10 AM
Colorado_Mustang
Colorado_Mustang's Avatar
Get an older Stang and you'll have more money for mods. I'd suggest a 5.0L model for limited budgets.
ORIGINAL: Falcon1
Colorado_Mustang is offline
Old 11-17-2006, 02:16 AM
onegreedy
onegreedy's Avatar
not worth it
i did it to a 1997 v6
from a 1997 v6 to a 1999 gt, total cost so far 5500.00
2200 for engine trans comp and wiring,
1000 for other parts (exhaust. irs rearend, water pump, power, steering pump, brake booster, ect)
400 for hand held tuner(to turn off pats )
2000 between labor and other crap
still not done, need 1 harness no one seems to know what it is! ! !
wiring was a biotch
but she runs and runs well, when she is not it a picky mood, if asked would i do it again, i woud say hell ya but this time with a 03-04 cobra motor
also no one will help you with this swap, they will do it for 5500 + parts, but no one will actually give you info on it
onegreedy is offline
Old 11-17-2006, 03:56 AM
Stang9946
Stang9946's Avatar
In older cars you can swap motors out like it's no ones business but not as easily with newer cars. You might as well just wait it out and buy an already V8 like already said.
Stang9946 is offline
Old 11-17-2006, 03:57 AM
Stang9946
Stang9946's Avatar
Old 11-17-2006, 09:01 AM
65coupe88hatch
65coupe88hatch's Avatar
Go for a 5.0 there all over the place for cheap, and with little money you can make them pretty darn quick if your on a limited budget, get one for like 3-4 grand and spend the remaining money on mods. Or you can wait it out and get the right year you like.
65coupe88hatch is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Can you change a V6 to a V8?
