Automatic Transmission Oil Change
Old 12-12-2006, 09:47 PM
MRock
MRock's Avatar
Default Automatic Transmission Oil Change
Anyone out there have the Ford specs and/or instructions to change the fluid and filter in the 5R55S Automatic Transmission.
MRock is offline
Old 08-04-2010, 03:20 AM
Forza_Roma
Forza_Roma's Avatar
Anyone?
Is it even possible to change it without special tools (like pump and so on)?
Forza_Roma is offline
Old 08-04-2010, 12:07 PM
JimC's Avatar
Yes it is possible. You need a simple tool for the fill process. I bought mine off Amazon. It goes up inside the fill hole -- the drain plug is two parts, you open the full plug to drain, remove the center part and insert the fill tool. You then have to use a hand pump to pump the transmission fluid up into the pan. When it starts to drain back out of the tool then the transmission is "full".
But, you have to start the car after that point and put it through the gears to get it up to operating temperature. The better practice then is to start the fill process again with the engine running and keep pumping fluid until it starts draining back out of the tool again.
JimC is offline
Old 08-04-2010, 01:59 PM
Forza_Roma
Forza_Roma's Avatar
Thank you!
Is the same procedure of filling process, if I replace AT filter too?
EDIT: Do you maybe have link to that tool on Amazon?
Old 08-04-2010, 05:29 PM
JimC's Avatar
Found the tool link:
http://www.amazon.com/OTC-6604-Trans...0960739&sr=1-1
If you are going to change the filter then you drain the fluid and then remove the pan. Clean the pan out (there is a magnet in the pan to capture any metal shavings so clean it off and put it back in place. The gasket is reusable. The filter just pulls out. There is an electrical fitting on the front of the pan that you need to disconnect but it has been awhile since I replaced the filter so I don't remember how it disconnects now.
Other than dropping the pan, the procedure is the same.
I bought a small hand pump that attaches to the quart bottle so I could pump the fluid in - but there are easier to manage hand pumps than the one I have, just make sure it will screw on to the bottle with a tight seal.
JimC is offline
Old 08-05-2010, 12:41 AM
Forza_Roma
Forza_Roma's Avatar
Ok... thanks for the instructions.
I already bought AT filter, gasket and 12 liters of ATF Mercon V (it's not easy to get all this stuff in Europe... and usually it's cheaper to import spare parts from US).
The only problem is that Amazon's shipping to Europe is very expensive so I'll try to find fill adapter somewhere else.
Car is approaching 60.000 miles, so I'll also be changing motor oil and filter, air filter, cabin filter and fuel filter. Official Ford service knowledge of American cars is very questionable here in Slovenia (they couldn't even get me fluid that fits Mercon V specifications)... in this way I'll rather do car service on my own.
Old 08-05-2010, 02:43 PM
Forza_Roma
Forza_Roma's Avatar
Should such hand pump be OK?
http://tinyurl.com/37bywf5
Old 08-05-2010, 08:10 PM
JimC's Avatar
that one should work - any pictures of your car by the way? Don't see many Mustangs outside of North America and I don't recall seeing any in Slovenia. Although I did see several when I was in London a couple of years back.
Someone just joined www.mustangcollective.com who has a Mustang and is in the Ukraine. He recently posted up some pictures from his club of various American cars on the streets for a get together.
JimC is offline
Old 08-06-2010, 01:20 PM
Forza_Roma
Forza_Roma's Avatar
Well... it's all stock V6 2005 Mustang.
Here are some pics from one of the US cars meeting in Slovenia (mine is sonic blue mustang):
http://www.american-car-club.com/for...5af9f7d0#p2746
I only added white mustang decals and changed colour of hood scoop (blue varnish was in very bad condition so I changed it to mate black - carwraping).
Oh... and I also added some aluminium accessories to car's interior.
That's how it looks now:
http://www.shrani.si/f/3y/SJ/2C2Gz0P...rafija0341.jpg
And that's the pic when the car was still in US:
http://www.shrani.si/f/20/10y/2YSe9ItU/4/p8061229.jpg
Back to the topic... I ordered hand pump, but this fill adapter is really giving me headaches.
Tool + shiping cost to Slovenia = 50$ ... I simply can't find any better options on the web.
djbigskrilla
09-20-2022 01:04 AM
CarrieS
09-01-2015 01:00 PM
Mr. D
08-26-2015 08:12 AM
1st 4 eyed fox
08-14-2015 09:55 AM
OBleedingMe
08-08-2015 12:02 PM
Quick Reply: Automatic Transmission Oil Change
