Air Fuel Ratio Gauge
Old 12-20-2006, 10:07 PM
89 5.0 Mustang
89 5.0 Mustang's Avatar
Default Air Fuel Ratio Gauge
Has anyone ever put an air to fuel ratio gauge in their car? If so i know you need to hook it up to the o2 sensors ,but how do you do it. Do you have to connect it to both o2 sensors?
89 5.0 Mustang is offline
Old 12-20-2006, 10:19 PM
Black Snake
Black Snake's Avatar
Default RE: Air Fuel Ratio Gauge
Just wire your possitive and negative wires and splice into the black wire on the O2 sensor
Black Snake is offline
Old 12-20-2006, 10:22 PM
89 5.0 Mustang
I'm glad you replied cause ive seen your car and the gauges, but so it comes with two wires. Do i put it into both, and im going with the ultra lites and when it is night time how do i wire them to come on when i turn on the lights?
Old 12-20-2006, 10:24 PM
Black Snake
I have Sport comps and as Far as I know it has 3 wires Red,Black and Purple. The purple is your signal wire.
The gauge doesnt light up the LED's light up to show fuel ratio
Old 12-20-2006, 10:26 PM
89 5.0 Mustang
Yea,ok but what about the others, im getting oil press and water temp. (I have no boost so i cant do boost gauge) Those will still light up right.
Old 12-20-2006, 10:47 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Yes
PRO50SC is offline
Old 12-20-2006, 11:05 PM
89 5.0 Mustang
Cool, and i know i ask tons of questions, and i just apreciat all the help all of have given me. Thanks
Old 12-21-2006, 04:09 PM
Wild_Side
Wild_Side's Avatar
ORIGINAL: Black Snake
I'm having the same question. I think I've tapped into the wrong wire. The black wire that you speak of for tapping into, that is on the O2 side of the pigtail, correct?
Oh, my car is an 87 GT.
Wild_Side is offline
Old 12-21-2006, 04:51 PM
luckythirteen13
luckythirteen13's Avatar
no one has bothered to mention that a narrow band o2 gauge is worth absolutly nothing and will not give you any information other then the o2s are working or not. you cant use it for tuning or checking to make sure the car is running correctly because th guage is constantly jumping around. its a glorified light show
luckythirteen13 is offline
Old 12-21-2006, 05:06 PM
samseed101
samseed101's Avatar
ORIGINAL: luckythirteen13
I was just about to mention that. Chances are, if you aren't sure how to hook it up, then you didn't know that you will want to get a wideband sensor. It's pricey, but the gauge isnt really worth it without the wideband sensor.
Then again, I don't see a need for the gauge unless there are some major engine mods.
samseed101 is offline
Quick Reply: Air Fuel Ratio Gauge
