PLEASE HELP..KEY STUCK IN IGNITION!!
Old 01-08-2007, 07:33 PM
blk89lx
blk89lx's Avatar
Default PLEASE HELP..KEY STUCK IN IGNITION!!
ok i need any help at all i was isntalling a radio in my car and i popped the radio fuse now after the install i cant get the key out of the ignition. it wont let me turn it all the way back to pull it out. ive checked all the fused in the box they are all good. im soo fed up with it i have no idea whats wrong. i had another ignition lock from my old car that worked fine so i switched it out andit still wont let me take the key out. i need help because im parking my car at school with the key in it.
blk89lx is offline
Old 01-08-2007, 07:36 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
Default RE: PLEASE HELP..KEY STUCK IN IGNITION!!
move the steering wheel back and forth
2 kwik is offline
Old 01-08-2007, 07:37 PM
gearbanger
gearbanger's Avatar
Did you press the little white button in the bottom of the steering wheel... lol thats all i can think of....and move your steering left and right.
gearbanger is offline
Old 01-08-2007, 07:39 PM
PJB
PJB's Avatar
Stupid question- is the car in park? If not the key wont come out.
I know on an automatic you need to put it in 1st to pop a deck in with the stock shifter.
PJB is offline
Old 01-08-2007, 07:42 PM
94gtcoupe
94gtcoupe's Avatar
if this is right ^^^^ then maybe you knocked the shift sensor a little and it doesn't know the care is in park
94gtcoupe is offline
Old 01-08-2007, 07:51 PM
ACE
ACE's Avatar
sounds like its in gear throw her in park!!!
ACE is offline
Old 01-08-2007, 07:53 PM
blk89lx
blk89lx's Avatar
OK EVERYBODY ITS IN PARK LOL. it will let me start the car but it wont turn back all the way to pull the key out. IM LOST
blk89lx is offline
Old 01-08-2007, 07:57 PM
94gtcoupe
94gtcoupe's Avatar
adjust the shifter linkage
Old 01-08-2007, 08:22 PM
Cool92GT
Cool92GT's Avatar
same thing happened to me. the pins inside fell apart. i had to have the car towed had a mechanic deal w/ it. he had to take off the steering wheel to remove lock and pins. so he installed a new lock and gave me a new key. costed me alot cause he spent alot of time doing it. It totally sucked.. especially because it happened on the 4th of july, so it's likely that thats what happened to you
Cool92GT is offline
Old 01-08-2007, 08:57 PM
vt89gtvert
vt89gtvert's Avatar
Well you do know about the little button on the bottom of the collum that you have to press in to allow it to turn out. I am guessing so since you have quite a few posts on here, but just a thought.
vt89gtvert is offline
Quick Reply: PLEASE HELP..KEY STUCK IN IGNITION!!
