Need help quick: How to tell if this is a true Cobra motor?
Old 01-10-2007, 08:50 PM
machzilla
machzilla's Avatar
Default Need help quick: How to tell if this is a true Cobra motor?
Well I'm going to look at motor tomorrow that I've been told came out of a '93 Cobra. Has 61K miles, came out of a car that had been rolled and totaled. Here's the question: How to tell if it's a true blue Cobra and not some POS a dude bolted a cobra intake onto.
I know what the differences are internally with the Gt40 heads and 1.7 rollers and all that but how to tell by looking at it while it's sitting on a trailer? What's the biggest clue I can readily see from the outside?
Anything that will prove it without a doubt?
Thanks in advance-
machzilla is offline
Old 01-10-2007, 08:52 PM
AdderMk2
AdderMk2's Avatar
Default RE: Need help quick: How to tell if this is a true Cobra motor?
24# injectors and cobra stamped valve covers
AdderMk2 is offline
Old 01-10-2007, 08:53 PM
5.0stanger
5.0stanger's Avatar
make sure they are gt-40's.
5.0stanger is offline
Old 01-10-2007, 09:22 PM
gspfunk
gspfunk's Avatar
I don't know the #'s off-hand, but find out what the block #'s should be as well as the tranny #'s. The Cobra's had an upgraded WC T5 tranny w/ steel bearing retainer and a few other things....rated at 310 tq instead of 300 like the WC.
gspfunk is offline
Old 01-10-2007, 09:54 PM
mnile9127
mnile9127's Avatar
ORIGINAL: AdderMk2
+1 Blue injectors, Gt-40 casting on the Heads
mnile9127 is offline
Old 01-10-2007, 09:59 PM
wythors
wythors's Avatar
The valve covers should also be stamped steel, not cast aluminum.
wythors is offline
Old 01-10-2007, 10:09 PM
machzilla
machzilla's Avatar
Ok, so blue injectors, stamped steel valve covers, and how to tell for sure on the heads?
Where to look on the heads for the Gt40 stamp? Is it cast in somewhere above the exhaust ports?
Old 01-10-2007, 10:31 PM
tortugasmoker
tortugasmoker's Avatar
mine is supposed to be a cobra motor too, but i dont know how to tell either, its really fast and its got a lot of goodies though, it also has denso yellow injectors i dont know how to tell what lbph they are though , it also came with a massive pro-m intake and a huge MAF sensor but i dont have a filter for it and its hard to find one that big.
tortugasmoker is offline
Old 01-10-2007, 10:45 PM
mnile9127
mnile9127's Avatar
Casting is on right corner of the heads. You have to be looking at the heads from
the exhaust sides. GT casting on the top and bottom right corners.
I had to look on my car. It's cold as hell, outside!!!!
GTP casting = GT-40P (spark plug bolt on different)
Granatelli Sales
01-20-2020 12:34 AM
11-10-2015 11:39 AM
treesloth
09-28-2015 07:03 AM
mrappe
09-26-2015 10:16 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: Need help quick: How to tell if this is a true Cobra motor?
