Oil pans on 91 2.3 na lx...
Old 01-11-2007, 02:09 AM
alboy91lx
alboy91lx's Avatar
Default Oil pans on 91 2.3 na lx...
Anyone have an easyer way to take the oil pan off???
[IMG]local://upfiles/58446/5CCE0C6894A746F9B671B2AF89E5FFC8.jpg[/IMG]
[IMG]local://upfiles/58446/F9533B145C7B4F3F8E344398C6D2E88C.jpg[/IMG]
alboy91lx is offline
Old 01-11-2007, 08:42 AM
wiseguy
wiseguy's Avatar
Default RE: Oil pans on 91 2.3 na lx...
You're probably going to have to unbolt the motor mounts and jack the engine up. The oil pan also bolts to the transmission, so don't forget about those. I changed pans when I replaced my engine, so I can't give you exact directions, but you will have to jack the engine up a little to get the pan to clear the crossmember. It's not super difficult, just time-consuming.
wiseguy is offline
Old 01-11-2007, 04:49 PM
alboy91lx
alboy91lx's Avatar
ive got everything thing done but i cant get the exshaust of to raise the engine more... to must rust....
Old 01-11-2007, 07:35 PM
sleeper_inc
sleeper_inc's Avatar
Just cut the Compression clamp (what ever its called) and it should be able to come out,
sleeper_inc is offline
Old 01-11-2007, 07:47 PM
alboy91lx
alboy91lx's Avatar
it says to take it off ater the mainifold... and the two bolts at the flange are rusted.... cut what??? were is it??? i dont wanna take it of at the mainifold of at the block... because to do it i have to raise the engine and tranny at the same time... and the pipe hits the body when coming up and wont bend...
Old 01-11-2007, 07:52 PM
sleeper_inc
Then cut the bolts, they will break if you try to take them out anyways.
Old 01-11-2007, 07:56 PM
alboy91lx
alboy91lx's Avatar
i guess and run open header for a few days until i get paid...
Old 01-11-2007, 08:00 PM
sleeper_inc
Yeah or you could buy 50 cents worth of bolts[&:]
Old 01-11-2007, 10:11 PM
alboy91lx
alboy91lx's Avatar
hell no open for a few days...
Old 01-11-2007, 11:21 PM
sleeper_inc
Then you can buy a 2.5" madral bent exhaust?[&:]
Quick Reply: Oil pans on 91 2.3 na lx...
