What are symptoms of bad PCV or vaccum leak
Old 02-02-2007, 11:03 AM
tron2003
tron2003's Avatar
Default What are symptoms of bad PCV or vaccum leak
As stated, I wondering what the symptoms of a bad PCV or vaccuum leak are? I just rolled into work with my 96 beater escort and when i put it in park the RPM's jump to just under 2k....So i figured I would check with you guys...thanks in advance
tron2003 is offline
Old 02-02-2007, 11:10 AM
DesertMach
DesertMach's Avatar
Default RE: What are symptoms of bad PCV or vaccum leak
Spuratic idle, stalling at idle, hesitation when accelerating, hard brake pedal if vacuum assisted, the car may shake at an idle also. hard starting. these all depend on the severity of the vacuum leak.
DesertMach is offline
Old 02-02-2007, 11:14 AM
tron2003
tron2003's Avatar
If you were to put money on why my idle is pinned @ just under 2k, what would you say?
tron2003 is offline
Old 02-02-2007, 01:35 PM
redgt2000
redgt2000's Avatar
take out you pcv valve, shake it if it rattles its good if it doesnt its bad. once thats solved move to your next thought.......vaccum leak
redgt2000 is offline
Old 02-02-2007, 01:39 PM
redgt2000
redgt2000's Avatar
but dam with those old escorts it could be anything
Old 02-02-2007, 01:53 PM
mariotraci
mariotraci's Avatar
vaccum leak
mariotraci is offline
Old 02-02-2007, 02:50 PM
8banger
8banger's Avatar
Follow the pvc hose to the top of the intake....and the hole for the vaccum leak ,,you will find...
8banger is offline
Old 02-02-2007, 02:52 PM
8banger
8banger's Avatar
ORIGINAL: redgt2000
Yeah,,I've replace a few intake gaskets also ,,around the no.1 or no 4 cyclinder(leaking vaccum)...your right could be several things..
8banger is offline
StalkerGT
09-25-2015 02:41 PM
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
fastbackford351
09-12-2015 09:42 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: What are symptoms of bad PCV or vaccum leak
