2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connectors
2005 mustang GT auto
Stoptech gt stage 2 braking system
Kenny brown strut tower brace
Bmr rear swaybar
Bbk airfilter kit
Bbk ceramic short headers
Magnaflow x pipe with racing cats
Magnaflow Cat-Back Exhaust System
Bbk 62mm twin throttle body
Moto blue pulley kit
brentspeed Sct tuner
Ford racing 4.10 gears
Comp cam racing cams stage1
comp cam valve steel retainers
comp cam valve springs
Ford racing cmcv delete kit
tci torque converter 3000stall
hey ppl what do you lot think of these are they any good and will they go good with my setup and has any one got them
Bmr rear swaybar
Bbk airfilter kit
RE: 2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connectors
I was running the GMS COPs and connectors for a few months. They had two strong points: They added about 20 HP to my S/C 4.6 and they completely eliminate spark blow-out on high boost applications.
So they are a good product for S/C cars. I think the results in n/a cars would not be as good.
Bad feature of them is I had two of them burn out last summer. While they were replaced under warranty, the reliability factor is a question now in my mind, so I have stock COPs on again. When I go to the track in April I will try them again to see if they make a difference in my ET.
The repacement coils are ONLY beneficial if you have forced induction and you are having problems with blowout due to high boost. On an N/A motor or FI with low boost they are useless.
Like Zkiller said, the GMS coils are not very good quality, and you always have to worry about them burning out.
Another option is the MSD coils. They are now available for the 4.6 COP. However, they are a very new product so I don't know any real-world feedback on them yet, but I would imagine they work like the GMS coils (only useful on FI), only I would expect them to last a lot longer.
Ozan, I realize this isn't what you asked about, but what stands out the most on your mod list is that you need a set of longtube headers to let those cams work to their highest potential. If you are looking for a mod to do, either longtubes or a 1-pc lightweight driveshaft is would be an excellent choice for your car.
thanks for your help guys so what good longtubes are there and lightweight driveshaft i dont mind doing them at the same time
thanks agen
thanks agen
I bought just the coil on connectors and felt a little difference. Dealing with Fords for a long time now and it tells me that Ford vehicles are picky when it comes to the electrical side. I would never change out the COP's themselves unless it's another set of Ford OEM COPs.
jaiidutch
09-14-2015 10:29 AM
