DPFE sensor
Old 02-19-2007, 01:32 PM
asix
asix's Avatar
Default DPFE sensor
Hey guys,
I've been having a problem with my 2004 manual v6 bucking when I let off the gas and sometimes almost stalling out when I come to a stop. It seemed to start when i put on my K&N Intake about a month ago but it could just be a coincidence. I thought it might have been my IAC valve soI replaced that and it didn't work. I have cleaned my MAF sensor and it still didnt help. I was thinking maybe it could be a problem with the DPFE sensor or EGR or something. What do you guys think. Any help is appreciated.
asix is offline
Old 02-19-2007, 05:19 PM
Baron von Munchausen
Baron von Munchausen's Avatar
Default RE: DPFE sensor
If nothing else works, consider re-installing your stock MAF screen (you'll have to be a little creative to do so). I would have said check for vacuum leaks, but you'vedone that already I'm sure.
TheDPFE sensor is said to be a weakness on sn95 Mustangs. I do not know what the symtoms are though of a bad one.
Baron von Munchausen is offline
Old 02-19-2007, 09:09 PM
nappypalms
nappypalms's Avatar
Is your Check Engine Light on? If so, go up to Autozone and have them scan it for ya.
Have you tried running any fuel injector cleaners or Seafoaming the engine?
nappypalms is offline
Old 02-19-2007, 09:58 PM
asix
asix's Avatar
What will the MAF screen do? No my check engine light is not on. I have ran injector cleaner but not seafoam. Was thinking about it pretty soon though.
asix is offline
Old 02-19-2007, 10:15 PM
nappypalms
nappypalms's Avatar
How many miles are on your Mustang?
Could need a tune-up (spark plugs/wires).
Old 02-19-2007, 10:54 PM
asix
asix's Avatar
Only about 40,000 miles.
asix is offline
Old 02-20-2007, 12:21 AM
asix
asix's Avatar
Im just curious. What does the MAF screen do anyways and why would it make a difference?
asix is offline
Old 02-20-2007, 02:54 AM
asix
asix's Avatar
Im pretty sure it has something to do with the DPFE sensor or the EGR system becauseI just unplugged the hose going to the EGR valve and whenI drove it around the problem seemed to go away.
asix is offline
Old 02-20-2007, 12:27 PM
cobra232
cobra232's Avatar
it's turbulence through the MAF. you either need to put a screen infront of the sensor or go back to the stock intake setup
if the screen doesn't work then try a straight filter mount to the MAF. It is a fender CAI correct? the 90 degree bend in CAI's are known to give turbulence at low speeds like at idle or coming up to a stop sign. too much turbulence and the meter gives incorrect fuel air demands and the car stumbles and stalls
cobra232 is offline
Old 02-20-2007, 04:21 PM
v6kid07
v6kid07's Avatar
symptoms of a bad one are having too much exhaust pressure because all it is. is an exhaust sensor lol i have replaced my dpfe with the new technology black one and the egr valve i replaced as well
v6kid07 is offline
Quick Reply: DPFE sensor
