Crank Journal specs
Old 10-28-2004, 10:38 PM
88PatrolCar
88PatrolCar's Avatar
Default Crank Journal specs
Does anyone know what the tolerances are on the journals of a 302 crank. Thanks Guys!
88PatrolCar is offline
Old 10-29-2004, 12:27 AM
86HOGT
86HOGT's Avatar
Default RE: Crank Journal specs
Get a manual! I was just doing the specs on a L99 4.3 V-8 Chev, it's 1.867"!! lol
86HOGT is offline
Old 10-29-2004, 02:16 AM
settled4automatic
settled4automatic's Avatar
oooo, i've been wanting to use this icon for the LONGEST time...... [sm=icon_rtfm.gif] harhar, i feel better :P sorry if you think i'm an ***, but i thought it was funny :P
settled4automatic is offline
Old 10-29-2004, 04:05 PM
roundman
roundman's Avatar
from my '88 manual, these are the specs.
MAIN BEARING JOURNALS
diameter = 2.2490-2.2482"
out-of-round limit = 0.0006 max
taper limit (per inch) = 0.0004 max
journal runout limit = 0.002
surface finish (RMS) = 12 max
runout service limit = 0.005
THRUST BEARING JOURNAL LENGTH = 1.137-1.139"
CONNECTING ROD JOURNAL
diameter = 2.1228-2.1236"
taper limit (per inch) = 0.0006 max
MAIN BEARING THRUST FACE
surface finish (RMS) = 35 front/25 rear
runout limit = 0.001 max
FLYWHEEL CLUTCH FACE
runout limit (T.I.R.) = 0.010"
FLYWHEEL RING GEAR LATERAL RUNOUT (T.I.R.)
standard transmission = 0.030
automatci transmission = 0.060
CRANKSHAFT FREE END PLAY = 0.004-0.008"
service limit = 0.012" max
CRANKSHAFT RUNOUT TO REAR FACE OF BLOCK (T.I.R. max) = 0.005"
roundman is offline
baddog671
07-26-2016 01:20 PM
robcy
Suspension
10-27-2015 11:14 PM
svfetter
10-05-2015 11:39 AM
EASTIDEE123
09-14-2015 03:52 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Crank Journal specs
