freeze plugs for 3.8
Old 03-06-2007, 01:09 AM
88blackgt
88blackgt's Avatar
Default freeze plugs for 3.8
I cant find it anywhere; what size freeze plugs does a carbed 3.8(essex) need? Just got an 86 notch w/ a 3.8 in it and the guy had all water in the coolant system, of course its all frozen now. Its getting a 5.0, but until then it would be nice to have it running. Thanks
88blackgt is offline
Old 03-06-2007, 06:19 AM
88blackgt
88blackgt's Avatar
Default RE: freeze plugs for 3.8
bump
Old 03-06-2007, 03:45 PM
88blackgt
88blackgt's Avatar
3.8 tech, you are disappointing
Old 03-06-2007, 04:23 PM
Jefferson
Jefferson's Avatar
Most of the members here in the V6 section have newer FI 3.8 engines. Be patient, not many people are carbed so your awnser may take mor time.
Jefferson is offline
Old 03-06-2007, 04:50 PM
88blackgt
88blackgt's Avatar
what does the FI 3.8 take? there are FI 3.8s in the essex family, so maybe they are the same. So what size freeze plugs does a FI essex 3.8 take?
Old 03-06-2007, 05:01 PM
laserred02
laserred02's Avatar
ok well i don't know where the freeze plugs are at, but i searched online and found that o'reilly auto parts has them for anywhere from $0.69 - $2.00 it may be worth heading up to your local auto parts store and asking them. freeze plugs are not a common thing that is changed most people probably don't even know what they are so i would think you may be waiting awhile for an answer on this forum...
you could also try posting at
www.mustangworld.com/forums
or
http://www.3.8mustang.com/forum/
sorry i couldn't locate them...but maybe i can point you toward some other resources
laserred02 is offline
Old 03-06-2007, 05:19 PM
02MustangV6DD
02MustangV6DD's Avatar
yeah, why not goto the auto store?
02MustangV6DD is offline
Old 03-06-2007, 05:27 PM
88blackgt
88blackgt's Avatar
already did, the computers dont tell which size. there are 3 different sizes, all very close to eachother. i know where they are supposed to be on the motor, i just need to know which size so i can put the right ones on. they were only .68 a piece, 3 different size, motor needs 2.
Old 03-06-2007, 06:31 PM
02MustangV6DD
well if there so cheap, why not buy all 6 and try them out?
Old 03-06-2007, 09:24 PM
88blackgt
88blackgt's Avatar
i did buy all 6. theyre pretty far up there and its hard to tell which is correct. did a test fitting and they all seem to kinda work. out of coolant so couldnt really check if they held coolant. either way it will be a complete pain in the *** to put them on, fill it up w/ coolant, and see if it holds pressure/coolant. not only that but i'll possibly have to fill it up w/ coolant 3 times. no one knows what size the freeze plugs are for a FI essex 3.8?
BOB ROME
07-26-2023 01:54 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
mrappe
09-26-2015 10:16 AM
col2560
09-25-2015 08:59 PM
Quick Reply: freeze plugs for 3.8
