remove ignition switch?
Old 03-16-2007, 09:32 PM
georgiaguy246
georgiaguy246's Avatar
Default remove ignition switch?
how do i remove the igniton switch for my car? i am just trying to get it from my '91 lx to my 87' gt. i am pretty sure they are the same but i don't have a manual to look at, my haynes sucks and couldn't find it. so if you guys could tell me how i would greatly apprechiate it as i am working on my car right now.
georgiaguy246 is offline
Old 03-16-2007, 09:41 PM
georgiaguy246
Default RE: remove ignition switch?
ttt can anyone help me? its getting dark pretty damn fast and i need this done tonight if anyone can help i would love it. thanks guys!
Old 03-16-2007, 09:44 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
The mechanical or electrical part?
PRO50SC is offline
Old 03-16-2007, 09:47 PM
georgiaguy246
not sure what its called but the part the key goes into. you can move it freely without the key and it will give power and such to the car so i need that switched. i already replaced the part where the wires go into, which i guess would be electrical.
Old 03-16-2007, 09:52 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Remove the plastic covering on the column. Turn the key to the on position. Look under where the lock cylinder goes into the column. There will be a lil pin sticking down through the column. Push the pin upward, remove the lock cylinder. Install in reverse. The lock cylinder MUST be in the on (not run)position for the the pin to depress.
PRO50SC is offline
Old 03-16-2007, 09:54 PM
georgiaguy246
alright thanks pro. and sorry for all the stupid questions lately and such. but thanks a lot!
Old 03-16-2007, 09:56 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
It's no problem. That's how you learn!!
PRO50SC is offline
jwog666
12-27-2021 08:09 PM
PaulH2
20
01-31-2016 09:48 AM
bradleyb
11-27-2015 07:50 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
Quick Reply: remove ignition switch?
