Jacking points
Old 03-23-2007, 12:42 PM
AndysJeeps
AndysJeeps's Avatar
Default Jacking points
This is a really dumb question.
When I go to work on the front end I have been jacking up the car on the front cross member, actually it's the only place I can find to lift it.
Is there do's and don'ts to lifting a Mustang? Jack stand placement.
AndysJeeps is offline
Old 03-23-2007, 01:04 PM
Lumbergh
Lumbergh's Avatar
Default RE: Jacking points
Front cross member is fine for jacking it up. I've also used the side rails for jacking and for the jackstands.
Lumbergh is offline
Old 03-23-2007, 01:14 PM
19stang66
19stang66's Avatar
I use a small wood block when I lift on the frame rails. Saves them from being dented from the metal circle deal on the jack.
19stang66 is offline
Old 03-24-2007, 01:59 AM
az1966
az1966's Avatar
right on with the wood thing,,orignal metal is only so strong and design stuff,,learned that one the hard way on another car
az1966 is offline
Old 03-24-2007, 10:49 AM
Niteshade
Niteshade's Avatar
Definitely use the wood blocks whereever possible because it also ditributes the load. Also never get under the car with it supported only by the jack.
Niteshade is offline
Old 03-24-2007, 08:25 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
A dude I knew was doing an oil change on a sloped driveway with a bumper jack, no chock, no emergency brake and suprise suprise, the car came off of the jack. His head was about 4 inches thick front to back when they got the car off of him. Dumb ***. May he rest in peace.
fastbackford351 is offline
Old 03-24-2007, 09:25 PM
Soaring
I ♥ Acer
Soaring's Avatar
If you are just changing a tire, the jack that came with the car fits under the rocker panel. You will see a slot cut out for the location. Now, if you are wanting the front or back, or both in the air, that's different. If you are using a bottle jack, then stop using a bottle jack. Get a decent floor jack (rated at least at 2000 lbs.)and jack up the front from the cross member in the front and the pumpkin in the rear. Always use chocks and have a manual transmission in reverse and an automatic in Park if you are lifting the front. Always, Always, Always use jack stands, and lots of them before you crawl under a car.
Soaring is offline
Old 03-25-2007, 12:44 AM
baddog671
baddog671's Avatar
ORIGINAL: Soaring
And American ones, I had a chinese piece of crap fold over from the weight even though it was well under the rated strength.[:'(]
baddog671 is offline
jwog666
12-27-2021 08:09 PM
flash_xx
10-16-2015 07:23 AM
marc954
09-29-2015 03:05 PM
09-25-2015 09:06 AM
Quick Reply: Jacking points
