Rear Brake Calipers Won't Compress... HELP!
Old 03-30-2007, 02:37 PM
baltimucho
baltimucho's Avatar
Default Rear Brake Calipers Won't Compress... HELP!
I see a lot of painted brake calipers here, so I'm hoping you can help me...
I'm replacing my stock brake pads with Hawks. The front pads went on fine, as I could compress the pistons with my hands. The rears calipers will NOT compress. I have removed one caliper COMPLETLY and disconnected the E-brake and rented a caliper piston compression tool and the piston will not BUDGE beyond it's original position. I can manually squeeze the E-brake mechanism and the piston pushes out, but I cannot get it move any further back.
The stock rear pads were almost gone and the new Hawks pads are almost 3 times the thickness of the current stock pads. I need almost 3/8 more clearance to get the rear calpiers over the new pads.
Am I missing something? Anyone else have this problem and find a solution?
Thanks you your help.
::mitch::
baltimucho is offline
Old 03-30-2007, 02:48 PM
baltimucho
baltimucho's Avatar
Default RE: Rear Brake Calipers Won't Compress... HELP!
Wow... Just POSTING to this forum makes me smarter!
Answer: Use the part of the compression tool that allows you to TURN and SCREW the piston back into the caliper. The rear caliper pistons don't PUSH back in.
You're welcome.
::mitch::
Old 03-30-2007, 04:12 PM
Feng Houzi
Feng Houzi's Avatar
[sm=youreright.gif]i ran into the same dilemma with my buddies 98 gt a few years back... i need to invest in that compression tool before i attempt that on mine!
Feng Houzi is offline
Old 03-30-2007, 05:00 PM
JasonIsAGeek
JasonIsAGeek's Avatar
compression tool? You mean a C-clamp? hehe
baltimucho I love those rims. Where did you get them?
JasonIsAGeek is offline
Old 03-30-2007, 07:04 PM
frodaddi
frodaddi's Avatar
I change my brake pads out forracing pads before track events, then back to OEM pads for the street, so I have done this a number of times. As you noted, the rear piston screws in, doesn't just push in like the front pistons.
A 'brake cube' like they sell at the local autoparts store doesn't fit unless you grind off 2 of the nubs on the side that has 4 nubs, like this:
After that it fits OK but still doesn't turn easily and wants to pop out of the slots, making me worry that I was going to damage the piston or boot. So I decided to spend the $43 and get a proper tool, which makesthe jobmuch easier:
http://www.amazon.com/gp/product/B00...404011-9905558
It's a decent tool for the price although of course the similar ones from Snap-On, Mac, etc are better but a good bit more expensive. But it fits well and makes me much less concerned about damaging the piston.
Kevin.
frodaddi is offline
Tivo304
08-28-2023 12:19 PM
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
cbird1177711
09-02-2015 08:51 PM
tj@steeda
Steeda Autosports
09-01-2015 08:16 PM
Quick Reply: Rear Brake Calipers Won't Compress... HELP!
