98 GT Need to change rear wheel bearing
Old 04-02-2007, 06:17 PM
JR1979
JR1979's Avatar
Default 98 GT Need to change rear wheel bearing
I picked upa bearing and seal today, need to change the driver's side rear wheel bearing. I have searched for directions but haven't found much. Anyone have a link to some directions? Or willing to type them up? Don't need to be too detailed, just the steps to get it done.
JR1979 is offline
Old 04-02-2007, 07:40 PM
sitnlopro99gt
sitnlopro99gt's Avatar
Default RE: 98 GT Need to change rear wheel bearing
you need a bearing puller that you can slip inside the bearing after you take the axle out and then just yank it..I will try to find a writeup for you....
sitnlopro99gt is offline
Old 04-03-2007, 09:31 AM
JR1979
JR1979's Avatar
Thanks.... I am not too mechanically inclined, but my brother is. He has a bearing press, but since it is on the axle I don't think you can use that, like you said, you need a puller. Is it a special puller? Or will something like a steering wheel puller do the job? Also, how do you get the new bearing back in? I assume you can't use a press for that either?
If you can find a write up that would be great!
Also, are there shims or anything elsewe need to know about when pulling the axle?
JR1979 is offline
Old 04-03-2007, 11:13 AM
BraMas
BraMas's Avatar
You have to release the axle from the differential. which requires you to remove the differential cover. If you have no idea what your doing in there you should leave it to a pro. It's not hard but you said your not mechanically inclined and you don't want to mess anything up. And the bearing puller can be rented at most good Auto Parts stores. The one you need is a slide hammer type
BraMas is offline
Old 04-03-2007, 01:21 PM
JR1979
JR1979's Avatar
my brother is going to help, he used to work at a garage. He just wanted to know what we were getting into, he has done wheel bearing before but never one where you have to pll the axle. Thanks, maybe I will just have it done, I already have the parts.
JR1979 is offline
Old 04-05-2007, 10:15 AM
JR1979
JR1979's Avatar
Default RE: 98 GT Need to changed rear wheel bearing, still making noise
I got the bearing changed, my noise is still there. There is like a rubbing sound coming from the driver side rear. When you jack the car up and spin the tire you can hear it. I have reached all around the tire and I am 99% sure it's not rubbing on anything. I have put800 miles on the car since I bought it so I would think if it was rust or something on the pads that would have cleared up by now, and if the breaks were rubbing I would think the shop would have noticed that when they disassembed the rear end to change the bearing? They did call before they did it and say the bearing wasn't loose and wanted to make sure I wanted them to go ahead and change it, I told them to go for it anyway since I had a few people who used to work a lot on cars say they thought it was the bearing. I am pretty sure he changed it because I already had the parts and when I went to pick it up he said I had the wrong seal and he had to go get one and he gave me back the seal I brought.
Any other ideas on what could be causing this problem?
JR1979 is offline
Old 04-05-2007, 11:20 AM
GodAmGT00
GodAmGT00's Avatar
Bad inner bearing maybe?? Or you could have a brake that's dragging, and you just don't notice it... If you get a chance, take the car out for a short ride, and put your hand NEAR (not on) the rotor, and if it feels considerably hotter than the other wheels, then there's your problem.. Normally a dragging brake doesn't make much noise though, so I'm not sure that's your issue..
JT
GodAmGT00 is offline
Old 04-05-2007, 11:37 AM
JR1979
JR1979's Avatar
inner bearing? Isn't there only 1 bearing per wheel? They had to pull the axle to change it. I'll double check the breaks. Any other ideas?
JR1979 is offline
drfister
05-03-2018 10:38 PM
Urambo Tauro
12-17-2016 03:30 PM
Urambo Tauro
09-07-2015 12:47 PM
gagemcc
08-26-2015 12:37 AM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: 98 GT Need to change rear wheel bearing
