quarter window moulding cover
Old 04-09-2007, 11:13 PM
  #21
Blue Oval
Blue Oval's Avatar
Default RE: quarter window moulding cover
dman that looks nice, im gonna have to get a set now. did they come painted or did you have to do it, and if you did what kind of paint does it matter?
Blue Oval is offline
Old 04-10-2007, 12:22 AM
  #22
Stanger89
Stanger89's Avatar
yea, I painted mine semi-gloss enamel, but I may have go for the full gloss.In his pics they look more shiney, and that looks good. Im also gonna try to paint allof theblack around the door the same color, gonna be a pain in the ***. Im wondering how much a shop would charge if I taped them off. After that, ill start working on the window rattles...any suggestions?
Stanger89 is offline
Old 04-10-2007, 12:49 AM
  #23
cleanfitty
cleanfitty's Avatar
That looks great... thanks for the pics. You are prolly the only one who has ever installed them the right way. Where did you get yours from???
Mine are in great shape, but I know 2 people with stangs that need them badly.
cleanfitty is offline
Old 04-10-2007, 10:19 AM
  #24
dman302
dman302's Avatar
WWW.BLUEOVALINDUSTRIES.COM for the covers, install was done using an aftermaket adhesive from local body shop supply company...stronger bonding properties than the supplied adhesive but unfortunately I don't recall the name. Make sure to test fit the molding several times so you can remove any excess material that may prevent a flush fit while also assist you in getting comfortable in which way you're going to place the moldings in place and where you may need extra adhesive. If they aren't sitting flush before you attempt install you'll have a hard time working with them when the adhesive is applied and smeering all over...excess glue will make it difficult for the tape to adhere properly and also make cleanup more difficult.
dman302 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
winner99
10-01-2015 01:06 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: quarter window moulding cover
