heater core problems
Old 04-25-2007, 07:32 PM
TRL12087
TRL12087's Avatar
Default heater core problems
for some time i had fog on my windshield coming out of my defroster, and recently i have had a pretty bad antifreeze leak coming from a tube coming out of the fire wall on the passenger side. yesterday my car began to smoke through the vents and began to over heat. is it the heater core? if so, how much work is involved in replacing it? also, my ac doesnt work, would it be better to change that when i do my heater core or does it not really matter?
TRL12087 is offline
Old 04-25-2007, 07:35 PM
mattdel
mattdel's Avatar
Default RE: heater core problems
heater core is bad, yes, and its a good weekend job if you've never done one. the whole dash must be removed.
do yourself a favor, go out and test your antifreeze for voltage. if you have more than 0.5 V running through your antifreeze, you need to add more ground straps and flush your coolant a few times. electrolysis is the reason that they break down and die, has nothing to do with the brand name of the core.
side note: your a/c has nothing to do with the heater core. probably needs a recharge.
mattdel is offline
Old 04-25-2007, 07:37 PM
Maxwelhse
Maxwelhse's Avatar
+1 on the heater core. Classic symptoms.
If you're near 45309 I can do both (I have A/C gear) and I could use the extra cash.
Maxwelhse is offline
Old 04-25-2007, 07:47 PM
TRL12087
TRL12087's Avatar
well thanks for the offer but im in mass. is it worth the time and effort to change it myself, or should i just bring it somewhere?
TRL12087 is offline
Old 04-25-2007, 07:51 PM
90lxstang
90lxstang's Avatar
it is well worth the effort i think. someone would charge you a few hundred bucks for something like that. it is an easy job just veeeerrrryyy time consuming.
90lxstang is offline
Old 04-25-2007, 08:03 PM
mattdel
mattdel's Avatar
i'm in mass as well, where are you
mattdel is offline
Maxwelhse
Maxwelhse's Avatar
I've heard of people getting quotes of like $700 at dealers... A corner repair shop might go half that, which is still a ton to install a $30 part.
Like he said, it ain't "hard", its just annoying and boring work. If I didn't need the cash, I wouldn't have offered! It took me a few days to do mine, but I did other things while I was there. Just take your time and try not to break the dash getting it out.
Also, make sure you install a resistrictor plug on the pressure side. There's a Ford part # for it somewhere. I just made one out of some stainless round stock.
Old 04-25-2007, 08:05 PM
mattdel
mattdel's Avatar
restrictor pipe isnt needed. its electrolysis that kills them.
mattdel is offline
Old 04-25-2007, 08:28 PM
Maxwelhse
Maxwelhse's Avatar
You're the first source, including the Ford written Mustang Performance Handbook, that has ever recommended not installing one for high performance applications.
I'm not trying to start a huge arguement, but its a cheap part (mine was free) that could make a difficult repair last a little longer and it can't possibly hurt. The only downside is the the heat takes about 10 more minutes to blow "hot" than it used to.
Seanam
10-04-2015 10:15 AM
ChampInSD
10-02-2015 04:55 AM
mdj89
09-23-2015 08:49 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: heater core problems
